« on: October 02, 2023, 04:45:40 PM »
« on: October 19, 2021, 06:36:52 PM »
« on: August 02, 2019, 12:27:16 AM »
MIDI ENGINE 8PORT/SE
Features
 Footswitch/trigger input
Requirements
MIDI compatible instrument(s)
Music software
MIDI Interface
SMPTE Synchronization
Patchbay Operation
Software Compatibility
Multi-Client Windows Driver
Windows Patchbay Software
« on: October 09, 2018, 07:21:36 AM »
see this thread
« on: September 18, 2018, 11:25:06 AM »
check the manual
Posted by: Mike Vangen
« on: September 16, 2018, 07:43:26 PM »
« on: January 28, 2018, 11:38:54 AM »
« on: January 22, 2018, 12:25:38 AM »
« on: July 14, 2017, 10:55:46 PM »
« on: March 03, 2017, 10:51:54 AM »
2000.
will not interface.
Microsoft Windows 98
Help topic in Regedt32.exe.
SYMPTOMS
RESOLUTION
Emergency Repair Disk (ERD).
00 00 to 00 00 00 00:
Type in Regedit and click OK.
“StaticVxD”=”*VCOMM”
“Start”=hex:00
« on: November 15, 2016, 10:40:30 AM »
further info from the readme
MIDIEngine 8Port/SE Notes
July 17, 1996
Driver version 1.5
CONTENTS:
: 8PSEDIAG Diagnostic Program
: Special Printer Port Notes
: 8FIXPORT Program
: 8Port/SE Sysex Commands
: Obtaining Technical Support
            -or-
1. Start Windows.
Drivers Icon.
'Restart Now'.
by default.
the 'Next' button.
and select Music Quest.
following:
corner of the window.
4. Exit File Manager.
subdirectory.
function.
warranty.
any system component.
>>>>>>>> Function
>>>>>>>> Running 8PSEDIAG
8PSEDIAG
and then press the ENTER key.
        or replace Print Manager
device=LEX01.386
;device=LEX01.386
of the printer port.
8FIXPORT Program
>>>>>>>> Function
>>>>>>>> Running 8FIXPORT
8FIXPORT
on this diskette.
>>>>>>>> Contact Us Directly
« on: September 21, 2014, 03:20:07 AM »
MusicQuest 8Port SE
Distinctive Features
Requirements
Music software
MIDI Interface
Patchbay Operation
