Posted by: OGF
Do you need help with that?
see this page :
Conclusion
steem emulator
&feature=youtu.be
replacing floppy drive info:
replacement models:
SAMSUNG SFD321B/ICL
SAMSUNG SFD321B/LE
SAMSUNG SFD321B/LFDWW TA
TEAC FD-235HFA549
YE-DATA YD-702D-6537D
CHINON FZ-357
CHINON 357-A
-FG
-REN
-HA
-HO2
-RY34
-DSO
Ringing the Changes
Time Sttrretchingg
Notching Disks
Problems
Verdict
