Hardware => Mixers => mixers - 1990s => Topic started by: chrisNova777 on January 28, 2019, 08:23:09 PM
http://www.muzines.co.uk/articles/soundcraft-6000-mixer/5826
(http://www.muzines.co.uk/images_mag/articles/sos/SOS_90_06_soundcraft_6_full.jpg)
SOUNDCRAFT 6000 SPECIFICATION
TOTAL HARMONIC DISTORTION:
Group (at 20dB above nominal level); <0.006% (1 kHz), <0.015% (10kHz)
Any output (+20dBu); <0.008% (1kHz), <0.02% (10kHz)
CROSSTALK: 1kHz 10kHz
Mic to line; <-90dB <-75dB
Line to mic; <-105dB <-94dB
Adjacent channel (line in/out); <-100dB <-90dB
Channel muting; <-108dB <-100dB
Fader kill; <-85dB <-84dB
Panpot isolation; <-90dB <-70dB
Routing (channel to group); <-110dB <-100dB
Aux send kill; <-85dB Not specified
NOISE:
(20kHz bandwidth, unweighted)
Mic input EIN (150 ohm source); -128dBu
Group noise (16 channels); -82dBu
Mix noise (16 channels); -87dBu
Aux noise (32 channel console); -84dBu
FREQUENCY RESPONSE:
Any input to any output; 20Hz to 20kHz (+0/-0.5dB)
INTERNAL HEADROOM:
Not less than 22dB at any point in console
Not less than 28dB at mix summing amps
Not less than 30dB at aux summing amps
INPUT AND OUTPUT IMPEDANCES:
Mic inputs; 2 kiloohm (balanced)
Line inputs; 20 kiloohm (balanced)
Outputs; 75 ohm
OUTPUT CAPABILITY:
Balanced outputs; Not less than 26dBu (600 ohm)
Control room outputs; Not less than 20dBu (600 ohm)
Other outputs; Not less than 22dBu (2 kiloohm)
