Hardware => Synthesizers + Romplers => synths - 1980s => Topic started by: chrisNova777 on August 17, 2017, 02:47:44 AM
(https://www.sequencer.de/pix/kawai_teisco/kawai-k1II.jpg)
https://www.sequencer.de/syns/kawai/K1II_K1IIr.html
https://encyclotronic.com/synthesizers/kawai/k1ii-r272/
https://soundprogramming.net/synthesizers/kawai/kawai-k1-ii/
same synthesis architecture as the original K1. There are 256 digital samples of waveforms, 50 of which are from acoustic instruments. You combine up to four wave shapes to create very new and unique sounds.
The K1 II is an updated version of the Kawai K1 with built-in reverb and improved drum sounds.
It is also available in rackmount form as the K1r II. It was not released in tabletop module form.
It has a single card slot and can be expanded with a variety of expansion cards.
Specifications
Year Released: 1989
Keyboard: 61 keys with velocity and aftertouch
Polyphony: 16 notes
Multitimbral: 8 parts
User Patches: 64
User Performances: 32
ROM: 256 8-bit PCM waveforms (204 additive waveforms, 52 acoustic samples)
Effects: 16 effects including reverb
Screen: 16x2 character backlit LCD
Dimensions: 936 mm x 260 mm x 80 mm
Weight: 6.9 kg
