« on: April 05, 2015, 02:16:11 PM »formerly known as the "Kenton Pro-Fade"
first http://www.kenton.co.uk later http://www.kentonuk.com/
http://web.archive.org/web/19990202091817/http://www.kenton.co.uk:80/pages/mantype.html
came in 8 + 16 channel versions?
http://www.soundonsound.com/sos/nov98/articles/kenton.htm
http://web.archive.org/web/20050305113829/http://www.soundonsound.com/sos/nov98/articles/kenton.htm
The CONTROL FREAK (formerly known as the Pro-Fade), is the latest addition to our range and is due for release this month. It has been designed to allow live, real-time editing of MIDI parameters and has a vast range of applications. Boasting eight programmable, proffesional-quality sliders and eight programmable buttons, it may be used to edit synth & sound module parameters, adjust sequencer controllers or to create versatile lighting effects - all in REAL-TIME !
Live editing is no longer limited to turning small knobs on your old analogue equipment... it is now possible to adjust parameters via MIDI ! Each slider or button may generate controller information, sysex, notes, program change, pitchbend or aftertouch, allowing instant control of up to 16 parameters. Editing is simple with the aid of a backlit LCD display and easy to use interface. Just imagine being able to control parameters such as VCF, pan, and pitchbend on your sequencer !
SPECIFICATION.
8 Fully programmable 60mm sliders
8 Fully programmable push-buttons
4 (x2 - with shift key) programmable function keys (Capable of sending any command or combination of commands. May also be used for instant program selection)
4 edit keys
Data entry knob
Two line back-lit LCD display
MIDI In/Out/Thru sockets
Two external 1/4" input jacks which may be used with a foot pedal to replace any slider or button.
External 1/4" input jacks may also be used for accurate CV / Gate to MIDI conversion !
Intuitive, easy to use editing and user interface (with text editor)
Supplied pre-programmed with profiles for popular synthesisers
On-board library with a capacity for over 5000 individual profiles
Advanced learn mode allows the user to match the unit to any synth
Future library updates will be available for direct download from our Website (Flash upgradable)
128 User memory locations each capable of storing assignments for every slider and button. (ie. 1024 virtual sliders and 1024 virtual buttons !)
Sliders and buttons may be individually named for every assignment in every memory location
Sliders and buttons can take a parameter from another slider (eg. If one button is set to send a note on message, it can take its velocity from a slider position)
Buttons may be operated in three modes : momentary (send command when pressed), toggle (toggle between two commands with subsequent presses) and on/off (send one command when pressed and another when released)
Sliders and buttons can send virtually any MIDI message in real time including multiple messages from the same slider / button
User selectable global MIDI channel feature which may, if required, override individual program settings
Built-in MIDI clock generator
Comprehensive MIDI analyser mode for identifying problems
Supplied with power adaptor (UK only)
Dimensions approx 270 x 160 x 55mm
ONLY £212.34 ex VAT / £249.50 inc VAT
http://web.archive.org/web/19990129021353fw_/http://www.kenton.co.uk:80/pages/cfrksp.html
