« on: December 19, 2014, 11:25:31 PM »I have confirmed this to be working on windows 3.11
after many errors + problems trying to install.. windows 3.11 is a particularly picky os about drivers + ram
and there are many complications that can arise.. but if you have a fresh windows install
and all your irq's + base addresses are configured properly this should install + work great.
i think my original problem was due to filesystem errors regarding filenames
or some sort of corruption caused by using a harddrive with a 40 pin cable in a UDMA66 port (udma66 requires 80 pin IDE cable)
and possibly also caused by experimenting with "32-bit file access"
after reformatting + installing on a purely 16bit windows 3.1 system works..
make sure to run oms setup first and successfully test your midi ins + outs
using 'test setup' option in oms setup.
more to come, including proper windows 3.11 screenshots
the correct serial is:
212.212.11111111
sepearated by '.' not by '-'
212.212.11111111
