« on: September 24, 2017, 04:24:01 AM »
https://www.computerhope.com/jargon/a/atx.htm
Short for Advanced Technology eXtended, ATX is a specification used to outline motherboard configuration and dimensions in an effort to improve standardization. First released in July of 1995 by Intel, ATX has since had many revisions. The first was version 2.01 in February 1997, then 2.03 in May 2000, 2.1 in June 2002, and 2.2 in February 2004.
ATX boards didn't hit the market in force until mid-1996, when they rapidly began replacing Baby-AT boards in new systems. The original ATX motherboard, often referred to as Standard ATX or Full-ATX, is 12" wide x 9.6" deep (305 x 244 mm). Its COM port, LPT port, PS/2, and USB are mounted directly on the motherboard. The image below is an example of the ATX form factor.
ATX computer motherboard
Advantages of the ATX motherboard
The ATX motherboard includes advanced control facilities, where the BIOS program continually checks the CPU temperature and voltages, the cooling fans RPM, etc. If overheating occurs, the PC will shut down automatically.
The ATX motherboard has a stacked I/O connector panel mounted on the motherboard.
On a socket 7 ATX motherboard, the socket has been placed a further distance from the expansion slots, allowing for long boards to be placed in easier.
ATX 2.01 includes a single keyed, Molex internal power supply connector which cannot be placed improperly. However, its standby voltage needs to be greater than 720 mA. While the Molex power connector allows for 5v and 3.3v to be connected, it is recommended that only a 3.3v be used.
Relocation of the memory and the CPU allows for better ventilation and easier installation.
Power management is now possible with proper BIOS support.
The PC can also be turned on by a modem or network signal, since the power supply is controlled by the main board.
The computer cannot be turned off as the computer boots. However, if the computer freezes as it is turning on you can turn off the computer by holding the power button for five seconds.
« on: September 20, 2017, 03:06:45 PM »
http://www.interloper.com/resultsmb.php?slot%5B%5D=Socket+7&model=&chipset=&bios=any&pcislot=&isaslot=&db9=&htx=&1X=&2X=&4X=&8X=&16X=&formfactor%5B%5D=ATX&width=&depth=&sataport=&usbport=&audios=any&btnSearchMb=List+Form
Biostar/M5ALA
Abit/AB-AX5
Atrend/ATC-5220
Atrend/ATC-5040
AOpen/AX5T
AOpen/AX59Pro
AOpen/AX59Pro
Asus/SPAX
Asus/TX97-X
Asus/TX97-XE
Asus/SPAX-M
Asus/P/I-XP55T2P4
Asus/TXP4-X
Asus/P5A
Asus/P5A
Asus/TX97-XV
Gigabyte/GA-586TX2
Gigabyte/GA-586ATX
Intel/Anchorage-/AN430TX
Intel/Tucson-/TC430HX
Intel/Advanced/AS (Atlantis) Motherboard
Intel/LT430TX
Intel/AN430TX
Intel/Marl
Intel/MS440GXT
Intel/Thor Motherboard
DFI/K6XV3+
Soyo/SY-5EMA+
Soyo/SY-5EMA
Soyo/SY-5STM
Soyo/SY-5EDM
Soyo/SY-5ED5
Microstar / MSI/MS-5169
Microstar / MSI/MS-5164
Microstar / MSI/MS-5148
Microstar / MSI/MS-5156
Microstar / MSI/MS-5128
Tekram/P5MVP-A4
Shuttle/HOT-597
ECS/P5TX-A
ECS/P5VP-A+
ECS/P5TX-Apro
EPoX/EP-MVP3G2
EPoX/EP-51 MVP3E
EPoX/EP-MVP4M/J
FIC/PT-2011
FIC/PA-2013
FIC/PA-2012
FIC/PA-2013
FIC/PA-2011
FIC/PT-2010
Micronics/M55HI+
Tyan/Titan 1571s
Tyan/Trinity S1592S
BCM/FR550
Iwill/XA-100
Iwill/XA100+
EPoX/EP-MVP3G-M
Tyan/Trinity S1598C2
Tyan/Tyan Trinity S1598
Tyan/Titan S1573 Turbo ATX-2
BCM/VP1541
EPoX/P55-VP3
BCM/VP1543
Chaintech/5TTM
Soyo/SY-5VX5
Gateway/4000277
Lanner/TF-586VM
Itox/G586ITOX
