Audio & MIDI => MIDI Interfaces => midi - Parallel (PC) => Topic started by: chrisNova777 on September 21, 2014, 03:20:07 AM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=351.0;attach=965;image)
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=351.0;attach=114;image)
(http://web.archive.org/web/19961113040957/http://www.opcode.com/products/winhardware/8port.gif)
MusicQuest 8Port SE
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=351.0;attach=803;image)
Distinctive Features
Footswitch/trigger input
Requirements
MIDI compatible instrument(s)
Music software
MIDI Interface
SMPTE Synchronization
Patchbay Operation
Software Compatibility
Multi-Client Windows Driver
Windows Patchbay Software
The included Windows Patchbay program allows the user to program, retrieve, and save 8Port/SE user programs; dynamically change MIDI routing and filter settings; and stripe and verify SMPTE tapes
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=351.0;attach=3424;image)
further info from the readme
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=351.0;attach=13517;image)
MIDIEngine 8Port/SE Notes
July 17, 1996
Driver version 1.5
: I M P O R T A N T !
CONTENTS:
: 8PSEDIAG Diagnostic Program
: Special Printer Port Notes
: Beware Other Printer Port Drivers
: Disable the LEX01.386 driver
: Disable Printer Port Arbitration on Some IBM Corp. Computers
: Micro Channel and Similar Printer Ports
: "Inverted" Printer Port IRQs
: 8FIXPORT Program
: 8Port/SE Sysex Commands
: Obtaining Technical Support
2. In Windows 3.1: from the Program Manager "File" menu, choose "Run..."
-or-
In Windows 95: click on the START button, then choose the "Run" menu item.
3. In the dialog box that appears, type A:\setup or B:\setup (depending on your drive name).
1. Start Windows.
Drivers Icon.
'Restart Now'.
by default.
the 'Next' button.
7. In the Add New Hardware Wizard, scroll down the Manufacturers list
and select Music Quest.
13. The Wizard now allows you to configure your interface. Please
following:
corner of the window.
4. Exit File Manager.
subdirectory.
function.
warranty.
any system component.
>>>>>>>> Function
>>>>>>>> Running 8PSEDIAG
8PSEDIAG
and then press the ENTER key.
or replace Print Manager
device=LEX01.386
;device=LEX01.386
of the printer port.
8FIXPORT Program
>>>>>>>> Function
>>>>>>>> Running 8FIXPORT
8FIXPORT
on this diskette.
>>>>>>>> Contact Us Directly
2000. Microsoft changed the configuration of those programs, and our drivers
will not interface.
Microsoft Windows 98
Help topic in Regedt32.exe.
SYMPTOMS
RESOLUTION
Emergency Repair Disk (ERD).
00 00 to 00 00 00 00:
Type in Regedit and click OK.
“StaticVxD”=”*VCOMM”
“Start”=hex:00
apparently the 8port/SE is only compatible with windows 95! +(presumably windows 3.x)
The only fly in the ointment is that some older hardware and software is no longer being actively sold and supported, and if you still use an elderly soundcard or MIDI interface, or a software application that is more than several years old, you may have an insurmountable problem if you find a conflict after upgrading. One brought to my attention recently is the Opcode 8Port/SE MIDI interface (which is now discontinued). Sadly its Patchbay utility has some problems running in Windows 98; although Opcode do suggest a workaround, the fact remains that in cases like these there is little likelihood of Windows 98 versions of discontinued software ever being written. This could be an important consideration that is worth checking before installing Windows 98 -- after all, the last thing you want is to have to spend yet more money replacing other PC hardware and software. http://www.oldschooldaw.com/forums/index.php?topic=3700.0
he 8PortSE is a MIDI interface designed for Windows that uses parallel port for communication with the computer. It is a versatile MIDI Patchbay/SMPTE sync device that supports 8 MIDI Ports (both In and Out).
It is renowned for low jitter and low latency and through the extraordinary work of developers such as Earth Vega Connection, drivers are available that work for all versions of windows up to Windows 10. Not bad for a device that was originally designed for DOS and Windows 3.1.
check the manual
see this thread
MIDI ENGINE 8PORT/SE
Features
Requirements
Music software
MIDI Interface
Patchbay Operation
https://godlike.com.au/index.php?id=138
ok after some fighting and many reboots... i finally got the driver to install again, and had to press the panic button on the front of the unit to get it to respond properly but its now passing my little test (testing each channel) again this time under the 22h2 windows 10 version. you REALLY have to shift-reboot and press 7 for disabling driver signing tryign to figure out how to permanently disable drievr signing so far i dont think ive figured it out yet
Windows 3.1 yes,, original driver from opcode/MQ, driver 1.62
Windows 95 yes,, original driver from opcode/MQ, driver 1.62
windows 98 yes,, original driver from opcode/MQ, driver 1.62
Windows 98SE yes,, original driver from opcode/MQ, driver 1.62
Windows 2000 possibly? with NT driver?
Windows XP possibly? with NT driver?, need a copy of the 32bit EVC WDM driver or EVC DM driver
Windows Vista 32 no, need a copy of the 32bit EVC WDM driver or EVC DM driver
Windows Vista 64 yes, EVC x64 default user driver /w driver signing disabled on boot
Windows 7 32 no, need a copy of the 32bit EVC WDM driver or EVC DM driver
Windows 7 64 yes, EVC x64 default user driver /w driver signing disabled on boot
Windows 8 32 no, need a copy of the 32bit EVC WDM driver or EVC DM driver
Windows 8 64 yes, EVC x64 default user driver /w driver signing disabled on boot
Windows 10 32bit no, need a copy of the 32bit EVC WDM driver or EVC DM driver
Windows 10 64bit yes, EVC x64 default user driver /w driver signing disabled on boot
