Software => Vintage Software => Digidesign Pro Tools => Topic started by: chrisNova777 on August 27, 2020, 01:26:07 PM
Title: pro tools MIX 24 (Sep 1998) system checklist
Post by: chrisNova777 on August 27, 2020, 01:26:07 PM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=7042.0;attach=11173;image)
http://archive.digidesign.com/support/mix/
http://archive.digidesign.com/compato/os9/mix/
http://archive.digidesign.com/compato/osx/mix/
https://www.sweetwater.com/sweetcare/articles/release-date-for-mix-core-mix-farm/
Sept/25/98
HW Interface: any one of the following
-888 i/o
-888/24 i/o
-882 i/o
-882/20 i/o (http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=355.0;attach=1542) http://akarchive.digidesign.com/support/docs/882_20_IO_Guide.pdf
-1622/24 i/o (1999) http://akarchive.digidesign.com/support/docs/1622_IO_Guide.pdf
"The 1622 I/O is designed for use with Pro Tools MIX and d24 cards. Do not connect it to DSP Farm or Pro Tools III cards."
"compatible with ProTools|24 MIXplus, ProTools|24 MIX, ProTools|24, Pro Tools III, ProTools Project systems"
these are the names of the different pre-configured bundles that were sold; depending on your configuration your system was labeled to be one of these series of pre-configured set-ups.
Cable:
need the proper "DigiLink MIX Cable" , HD uses different cable connector
"For MIX, d24, and PTIII PCI systems you need a DB60 connector and a SCSI-2 50 pin connector to make these cables. "
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=7042.0;attach=11171;image)
Card: any one of the following
-MIX Core PCI Card (1998)
-MIX Farm PCI Card
ProTools 24 MIX Plus is basically the 2 card combination consisting of 1 core + 1 farm card as a pair
https://www.sweetwater.com/sweetcare/articles/what-difference-between-mix-core-mix-farm/
Both cards provide similar DSP power, but Pro Tools requires a “Core” card to be able to run. Valid card configurations must include a MIX Core or a d24 Core.When multiple DigiSerial Ports exist in a system, only the DigiSerial Port on the first card (lowest numbered slot) is active.
-MIX I/O PCI Card
-d24 PCI Card http://www.oldschooldaw.com/forums/index.php/topic,1080.msg1121.html#msg1121
-Project II PCI Card http://www.computinghistory.org.uk/det/55662/Digidesign-Project-II/
-Pro Tools Project PCI Card,
-Disk I/O PCI Card
-DSP Farm PCI Card
the different PCI interface cards that can be connected to the external audio interface units
Mac:
g3/g4 Macintosh running MacOS8/9
(or any earlier PCI Macintosh, ie: 9600, 8600)
Software:
Pro Tools TDM 5.1.3
https://macintoshgarden.org/apps/pro-tools-513-tdm
Optional:
ADAT bridge/24 unit Digidesign ADAT® Interface
SampleCell II - PCI SampleCell II TDM Module - PCI
SMPTE Slave Driver (w/SSD Setup 1.3)
Video Slave Driver
http://web.archive.org/web/19970516061307/http://www.digidesign.com/Newdigiweb/Digiservice/Compatofolder/compatindex.html
http://macos9lives.com/smforum/index.php?topic=435.0
October 1997
https://www.sweetwater.com/publications/sweetnotes/sn-fall97/page-02.html
Pro Tools|24 provides digital recording,Pro Tools editing, and mixing with true 24-bit audio performance and up to 24 discrete tracks per audio card, plus 24 tracks of I/O capability with your Core System. Add powerful real-time DSP effects, advanced automation, integration with MIDI and digital video, plus support for a host of TDM and AudioSuite Plug-Ins and you've got the makings of a true, world class recording suite.
You begin with a "Core System" which includes a d24 audio card. This is a PCI-bus card which connects to your choice of Digidesign Audio Interfaces, either the 888|24 I/O ($3495 list) or 882 I/O ($995 list).
July 1999
https://www.mixonline.com/recording/digidesign-pro-tools24-mix-cross-platform-workstation-375001
Pro Tools|24 MIX ships in two different configurations, Pro Tools|24 MIX ($7,995) and Pro Tools|24 MIXplus ($9,995). Both are built around the MIX Core PCI board, a card that can handle up to 64-voice simultaneous playback (with a maximum of 128 tracks) and 16 channels of I/O.
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=7042.0;attach=11169;image)
heres a nice system description:
http://www.classicrecording.com/protools.php
https://medias.audiofanzine.com/images/normal/digidesign-pro-tools-24-mix-cube-2776833.jpg
