Hardware => Hardware Samplers & MPCs => samplers - 1980s => Topic started by: chrisNova777 on October 25, 2016, 08:27:25 AM
Title: 19" akai s950 (1988) midi digital sampler
Post by: chrisNova777 on October 25, 2016, 08:27:25 AM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=3154.0;attach=5295;image)
(http://www.polynominal.com/akai-s950/akai-s950.jpg)
(http://www.muzines.co.uk/images_mag/articles/xMT_jan_1989_akai_s950_di_large.jpg.pagespeed.ic.oxndkNFp9a.webp)
Ringing the Changes
Time Sttrretchingg
Notching Disks
Problems
Verdict
Title: sending samples via Serial Port / RS232
Post by: chrisNova777 on November 26, 2016, 10:55:18 AM
Title: Re: akai s950 (1989)
Post by: chrisNova777 on January 02, 2017, 03:55:03 PM
&feature=youtu.be
replacing floppy drive info:
replacement models:
SAMSUNG SFD321B/ICL
SAMSUNG SFD321B/LE
SAMSUNG SFD321B/LFDWW TA
TEAC FD-235HFA549
YE-DATA YD-702D-6537D
CHINON FZ-357
CHINON 357-A
-FG
-REN
-HA
-HO2
-RY34
-DSO
http://torlus.com/floppy/forum/download/file.php?id=226&fbclid=IwAR07NI4KTvdDvDeEJZlKE2SObqGZXgzQePGzVPqkmhXxP3NfczaPrEH3DxA (http://torlus.com/floppy/forum/download/file.php?id=226&fbclid=IwAR07NI4KTvdDvDeEJZlKE2SObqGZXgzQePGzVPqkmhXxP3NfczaPrEH3DxA)
Title: does STEEM work with Drum Filer + S950?
Post by: chrisNova777 on January 27, 2017, 09:44:24 AM
steem emulator
Post by: chrisNova777 on May 31, 2017, 08:17:12 PM
Post by: chrisNova777 on June 23, 2017, 07:59:38 PM
(http://www.muzines.co.uk/images_mag/scans/mt/mt_91_04/l/mt_91_04-83.jpg)
Post by: chrisNova777 on July 16, 2017, 05:07:44 PM
(http://www.muzines.co.uk/images_mag/scans/mt/mt_89_01/l/mt_89_01-52.jpg)
Title: Re: akai s950 (1989) midi digital sampler
Post by: chrisNova777 on January 11, 2019, 06:00:37 AM
(http://www.muzines.co.uk/images_mag/scans/sos/sos_89_10/l/sos_89_10-21.jpg)
Title: external floppy emulator allows both floppy + sd card to be used!!!!
Post by: chrisNova777 on January 22, 2019, 08:56:09 AM
Post by: chrisNova777 on January 30, 2019, 12:59:41 PM
(http://www.muzines.co.uk/images_mag/articles/HSR_mar_1989_akai_s950_large.jpg)
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=3154.0;attach=7106;image)
Conclusion
Post by: chrisNova777 on February 07, 2019, 08:08:52 PM
Post by: chrisNova777 on February 18, 2019, 10:24:29 PM
Post by: chrisNova777 on April 07, 2019, 05:48:06 AM
Title: Re: 19" akai s950 (1988) midi digital sampler
Post by: chrisNova777 on August 31, 2023, 11:50:39 PM
see this page :
Post by: OGF on September 01, 2023, 04:30:27 AM
Do you need help with that?
