Audio & MIDI => MIDI Interfaces => midi - USB Midi Interfaces => Topic started by: chrisNova777 on September 12, 2014, 11:56:47 PM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=322.0;attach=6056;image)
https://web.archive.org/web/20150409171422/http://www.soundonsound.com/sos/jan00/articles/emagicamt8.htm
http://www.potm.org/software/Unitor/
https://web.archive.org/web/19991127090438/http://emagic.de:80/english/products/hardware/amt8_u8_2.html
https://web.archive.org/web/20150323030028/http://www.soundonsound.com/Contents.php?Month=1&Year=2000
(https://web.archive.org/web/20000116095244im_/http://www.emagic.de:80/english/images/products/u8_amt8/amt8_b.jpg)
System Requirements Windows
Windows 95 or Windows 98
min. 486 DX2/66
min. 12 MB RAM
free COM-Port (1-4)
System Requirements Macintosh
Mac 7.0 or higher
min. 12 MB RAM
free modem or printer port or USB
Feature List AMT8 and Unitor8 MkII
Mac compatible (AMT, MTP emulation and OMS)
Windows 95/98 compatible (AMT, MME)
Ready for Windows 2000
AMT in conjunction with AMT compatible software (e.g. Logic Audio)
MME compatible multi-client MIDI driver (multiple midi programs can use different MIDI ports simultaneously)
8 independent MIDI Inputs with Activity LED
8 independent MIDI Outputs with Activity LED
8 units per port* (mixed AMT8/Unitor8/Unitor8 MkII systems possible)
Stand Alone Operation with 32 Patches
Connection Activity LEDs (Mac/PC/Network)
Panic/Patch button
RS-422 connection for Macintosh (cascade connection for PC)
RS-232 connection for PC (cascade connection for Mac)
USB connection for new PowerMacintoshs (PC drivers in development)
Unitor8 Control Software for Mac/Windows 95/98 included
External Power Supply included
Additional Unitor8 MkII Features
LTC/VITC Generator and Reader with extremely short lock times
LTC Sync at 12-1000% original tape speed - and during rewind!
VITC-Synchronization during single frame advance forward/backward
Timecode Video Burn-In - also during LTC Sync
Timecode Refresh function, adjustable Freewheeling, Jam Sync function
Adjustable MTC Full Frame Message (e.g. for ProTools or Paris)
Operating system can be updated via SysEx
Input for audio trigger signal or single/double foot switch
LTC/VITC read and write control LEDs
LTC In and Out, 1/4" jacks
VITC In and Out, S-Video connectors
* Mac: up to 192 MIDI ports (using 2 serial ports and USB).
Windows 95: limited to 11 MIDI Ports.
Windows 98: 64 MIDI Ports (ready for more ports with future driver versions).
AMT8 - USB MIDI interface ships in September
Emagic announces that the AMT8, the new 8 x 8 USB-compatible MIDI interface for Mac and PC, ships in September 1999.
AMT8 - Active MIDI Transmitter
The AMT8 is based on Emagic's successful Unitor8, the 8 x 8 MIDI interface/synchronizer, but without the SMPTE synchronization. The AMT8 can be mixed or stacked with any Unitor8/Unitor8MkII combination and includes Emagic's unique Active MIDI Transmission (AMT) technology. This ensures that AMT8/Unitor8 systems driven by AMT-compatible MIDI software will provide superior timing quality, equivalent to the timing of hardware based sequencers. Up to 8 Emagic interfaces can be stacked on a single RS-232, RS-422 or USB port.
Logic Audio Version 4.0.1 is required in order to use AMT8 with the USB connection found on the latest Macintosh computers. The 4.0.1 update CD for current Logic Audio 4.0 users is included.
Availability
International deliveries of AMT8 begin in September.
-- http://web.archive.org/web/20000301175045/http://www.emagic.de/english/news_ar/index.html
Emagic announces the Unitor8 MkII
Emagic is proud to announce the successor to the Unitor8: the Unitor8 MkII. This release further exemplifies Emagic's commitment to emerging industry standards.
Unitor8 MkII
The Unitor8 MkII is a 19", single rack-space, synchronizer and MIDI interface for Mac or Windows operating systems. Each unit has 8 MIDI inputs and 8 independently addressable MIDI outputs. In addition, it can read and write SMPTE as LTC and VITC. The Unitor8 MkII can also easily read LTC from 1/4 to 4x normal speed. With VITC synchronization, Logic will support freeze-frame and reverse playback. In contrast to the earlier model, the Unitor8 MkII can now be connected via a USB port. The existing connections via RS-232 and RS-422 remain unchanged but the Mac Thru connector has been eliminated to make room for the addition of the USB connection. Unitor8 MkII is fully compatible with Emagic's Unitor8 and AMT8 interfaces, meaning that up to 8 units can be stacked to control complex MIDI studios.
The Unitor8 MkII offers all the features familiar from its successful predecessor: outstanding reliability, a SMPTE generator and reader with extremely short lock times for LTC and VITC in all formats, Active MIDI Transmission (AMT) technology, video picture timecode burn-in, a click/footswitch input, stand-alone patch bay functions and many other options.
Logic Audio Version 4.0.1 is required in order to use AMT8 with the USB connection found on the latest Macintosh computers. The 4.0.1 update CD for current Logic Audio 4.0 users is included. Unitor8 MkII also ships with the Unitor8 Control editing software.
Availability
International deliveries of Unitor8 MkII begin in September.
The provided system extension ("stealth serial port 1.0.2" or "gPort Driver") is REQUIRED if you use Logic Audio 4.0.1, or SoundDiver 2.1 or Newer. These versions confirm the existance of the serial ports. Without these system extensions, the system does not know that the stealth or gport is installed; and the modem port will not be available in Logic / Sound Diver.
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=322.0;attach=6052;image)
http://web.archive.org/web/20000815212307/http://www.geethree.com/9.0.4.html
