Hardware => Effects Processors => Compressors => Topic started by: chrisNova777 on December 03, 2015, 01:12:44 PM
http://www.sweetwater.com/store/detail/266XS
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=2127.0;attach=2559;image)
Great sounding dynamics control for any program material
New gate timing algorithms ensure the smoothest release
Program-adaptive expander/gates
LEDs for gain reduction, compression and gate threshold
Stereo or dual-mono operation
Balanced inputs and outputs on 1/4" TRS and XLR connectors
Side Chain insert
Classic dbx Auto mode for nearly error-proof operation
http://web.archive.org/web/19970717074845/http://www.dbxpro.com:80/p1stuff/10p1266.htm
SPECIFICATIONS:
FREQUENCY RESPONSE:
Flat: 20Hz-20kHz, +0, -0.5dB
Bandwidth: 0.35Hz-80kHz, +0, -3dB
INPUT: (Balanced, Unbalanced)
Impedance: 100k
Max Level: +20dBu
OUTPUT:
Impedance: 50
Max Level: +2-dBu into 600
SIDE CHAIN INSERT:
Input Impedane: >10k
Output Impedance: <2k
Max Level: +22dBu
Distortion + Noise: <0.2% any amount of compression at 1kHz
Intermodulation Distortion: <0.2% SMPTE
Noise: <-93dBu unweighted
Dynamic Range: 113dB, unweighted
Crosstalk: <-93dB @ 1kHz
Common Mode Rejection: >40dB (Any Frequency)
Stereo Coupling: True Power Summing
Threshold Characteristics: Comp OverEasy®
Exp/Gate: Program Dependent Threshold
Compressor: OverEasy; -40 to +20dB
Expander/Gate: -60 to + 10 dB
RATIO:
Compressor: 1:1 to :1
Expander/Gate 1:1 to 4:1
ATTACK TIME:
Compressor: Scalable Program
Dependent
Expander/Gate: <100 µsec
Release Time:
Compressor: Scalable Program Dependent
Expander/Gate: Program Dependent
POWER REQUIREMENTS:
18 VAC provided by external power supply included with unit. Specify mains voltage when ordering.
DIMENSIONS:
(H x W x D) 1.75"x4"x19" (4.45cm x 10.16cm x 48.5cm)
WEIGHT:
Net Weight: 5 lbs. (2.3 kg);
Shipping Weight: 7 lbs. (3.2 kg)
