Audio & MIDI => MIDI Interfaces => midi - ISA (mpu-401) => Topic started by: chrisNova777 on November 14, 2016, 06:18:54 PM
MIDI Edge 1x1
http://web.archive.org/web/19970125151329/http://www.etcetera.co.uk/et03013.htm
The MIDI Edge 1x1 is the affordable MIDI interface solution for the serious PC musician. The card has a standard Waveblaster Compatible daughter board connector so it is Perfect for getting the most out of Yamaha's award winning DB50XG or any waveblaster compatible daughter board. The MIDIEdge 1x1 has 1 MIDI in port for 16 channels inputs and 1 separate output for 16 MIDI out channels.
16 MIDI playback channels through 1 port
16 MIDI record channels
Selectable ports and IRQ settings (IRQ ,2,5 or 7; port 330,332,334 or 336)
26 pin Waveblaster compatible connector to connect any waveblaster compatible daughter board
Windows 3.1x and Windows 95 compatible
CE
