Audio & MIDI => Audio Interfaces => PCI Audio Interfaces => Topic started by: chrisNova777 on October 23, 2014, 06:48:52 PM
http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=444.0;attach=9003
RME Digi96.rar contains drivers for win9x,XP & OS9, OSX Panther
https://archiv.rme-audio.de/en/downloads/driver_updates_readme_digi96.php
October 1998: RME introduces and ships the DIGI96 series, the world's first 24-Bit/96kHz capable digital audio card series.
http://www.rme-audio.de/news/en_list_of_records.php
http://web.archive.org/web/20001203154900/http://www.rme-audio.com/english/index.htm
PAD / english https://www.rme-audio.de/download/968pae.pdf
asio driver can handle up to FOUR cards - under which os? probably win98SE?
windows 98/se/me 2000/XP + mac os 8.6 > 9.22
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=444.0;attach=934;image)
Stereo Analog i/o + SPDif i/o + ADAT i/o = 12 inputs/outputs
PAD: http://www.rme-audio.de/download/968pae.pdf
http://www.soundonsound.com/sos/feb02/articles/rmedigi0202.asp
PST: http://www.rme-audio.de/download/968pse.pdf
http://www.rme-audio.de/old/english/digi96/digi96ps.htm
Features 2 channels digital SPDIF in/out, 8 channel digital ADAT in/out, 2 channel Analog in/out
total inputs: 12
total outputs: 12
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=444.0;attach=346;image)
rme download center (2006)
http://web.archive.org/web/20060622002639/http://www.rme-audio.com/english/download/index.htm
does anyone know if this cards driver will work under osx Tiger?
from what i can see it most likely was last officially supported under Panther
digging deeper into the driver file i find:
This driver was tested under Jaguar 10.2.8 and Panther only. Older versions of OS X are not and will not be supported.
if anyone has any info about it working or not working under osx tiger 10.4 that would be helpful info
here is the macosx Driver (10.2.8+)
found from here:
http://web.archive.org/web/20060623191149/http://www.rme-audio.com/english/download/drivers.htm
apparently the driver is not INTEL compatible;
but there is a chance it may work on OSX TIGER on a PPC G4
(many PST cards are not electrically compatible with the G5)
does anyone know if the RME 96/8 PST works on windows 7? 8)
apparently it is rumoured to work fine under windows 7 32bit with the XP driver
but not under 64bit
I think it will work on any 32bit version of windows, windows 10-32bit probably works with the same 2.11 driver
i can confirm that the DIGI 96/8 PST does indeed work under OSX TIGER 10.4.11 on a powermac G4 using the posted OSX driver.. it is a bit confusing though.. using DIGI96 settings app is required
i've just tested it on a 1.25Ghz MDD with 750MB of RAM + a USB 2.0 NEC card, Radeon 9000 Pro Graphics
please make sure to read this before installing digi96 series cards in your G5
http://web.archive.org/web/20060716060218/http://www.rme-audio.com/english/mac/osxcom.htm
also we should start a proper VOGONS style driver archive
