Author Topic: 19" akai s950 (1988) midi digital sampler  (Read 16030 times)
« on: October 25, 2016, 08:27:25 AM »
Ringing the Changes
Time Sttrretchingg
Notching Disks
Problems
Verdict
sending samples via Serial Port / RS232
« Reply #1 on: November 26, 2016, 10:55:18 AM »
Re: akai s950 (1989)
« Reply #2 on: January 02, 2017, 03:55:03 PM »
&feature=youtu.be
replacing floppy drive info:
replacement models:
SAMSUNG SFD321B/ICL
SAMSUNG SFD321B/LE
SAMSUNG SFD321B/LFDWW TA
TEAC FD-235HFA549
YE-DATA YD-702D-6537D
CHINON FZ-357
CHINON 357-A
-FG
-REN
-HA
-HO2
-RY34
-DSO
does STEEM work with Drum Filer + S950?
« Reply #3 on: January 27, 2017, 09:44:24 AM »
steem emulator
« Reply #4 on: May 31, 2017, 08:17:12 PM »
« Reply #5 on: June 23, 2017, 07:59:38 PM »
Re: akai s950 (1989) midi digital sampler
« Reply #7 on: January 11, 2019, 06:00:37 AM »
external floppy emulator allows both floppy + sd card to be used!!!!
« Reply #8 on: January 22, 2019, 08:56:09 AM »
« Reply #9 on: January 30, 2019, 12:59:41 PM »
Conclusion
« Reply #10 on: February 07, 2019, 08:08:52 PM »
« Reply #11 on: February 18, 2019, 10:24:29 PM »
« Reply #12 on: April 07, 2019, 05:48:06 AM »
Re: 19" akai s950 (1988) midi digital sampler
« Reply #13 on: August 31, 2023, 11:50:39 PM »
see this page :
Offline OGF
« Reply #14 on: September 01, 2023, 04:30:27 AM »
Do you need help with that?
