Audio & MIDI => MIDI Controllers => controllers - NON-USB => Topic started by: chrisNova777 on November 14, 2016, 06:35:04 PM
http://web.archive.org/web/19970125151416/http://www.etcetera.co.uk/et03025.htm
(http://web.archive.org/web/19970125151416/http://www.etcetera.co.uk/cbxk1.jpg)
(http://c1.zzounds.com/media/fit,2018by3200/quality,85/p12748h-fad6a4a5d70c2456da2ac5152ce3fba4.jpg)
The ideal mini keyboard for data entry and editing with XG tone generators such as the MU80 and MU50.
In addition to note entry, the CBX-K1 allows easy, real-time control of voice and effect parameters, making it an indispensable tool for XG MIDI programming. The CBX-K1 is a compact, highly portable 37 key MIDI keyboard, designed especially for use with computers and MIDI music systems. The CBX-K1 does not generate any sound itself, but can be used as a keyboard controller for playing sounds on a connected tone generator or rhythm machine. It is also ideal for recording to sequencerss and computers.
The Keyboard is touch sensitive and it's octave range can be changed to cover the full 128 MIDI range.
The CBX-K1 has an assignable wheel that can be set for control of any controller number.
This means that you can use the assignable wheel to control a wide variety of parameters on your connected tone module - such as volume, pan, brightness, and the depth of various effects in real time. This gives you expressive control over different aspects of the sound in live performance.
Touch sensitivity for natural dynamic control.
Assignable wheel can be used to send a variety of MIDI messages.
MIDI merge function.
Compact dimensions for comfortable desk-top use.
Battery power for portable operation.
OTHER IMPORTANT SPECIFICATIONS
keyboad : 37 mini key keyboard(C2-C5), velocity responsive
INPUT/OUTPUT Terminals : MIDI IN/OUT, DC IN
