Hardware => Hardware Samplers & MPCs => samplers - 1990s => Topic started by: chrisNova777 on March 22, 2015, 06:58:46 PM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=860.0;attach=1014;image)
http://akai.mnx2010.nl
http://web.archive.org/web/19990429140601/http://www.soundsonline.com/ew*TEMPLATE%3D/ew/htp/akai.htp (http://web.archive.org/web/19990429140601/http://www.soundsonline.com/ew*TEMPLATE%3D/ew/htp/akai.htp)
default config (non-expanded)
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=860.0;attach=1016;image)
Creating OS disks:
chronological list of akai "s series" samplers (excluding mpcs) (http://www.oldschooldaw.com/forums/index.php?topic=805.0)
http://akai.mnx2010.nl/
editable with:
EXPANSION OPTIONS
• IB304F FILTER BANK
• MORE MEMORY
• EXTRA STORAGE
some suggestions for cdroms:
hp cd-writer 9600 series
yamaha crw3200sx
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=860.0;attach=3969;image)
(http://macintoshgarden.org/sites/macintoshgarden.org/files/screenshots/mesa2_logo.gif)
Features:
mutec-net.com
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=860.0;attach=4988;image)
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=860.0;attach=6991;image)
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=860.0;attach=7331;image)
