« on: January 14, 2019, 05:50:45 AM »AKAI IB208P (Multi8/D) - S/PDIF + Assignable Outputs
« on: April 06, 2018, 07:06:38 PM »https://jimatwood.wordpress.com/2011/05/17/akai-s2000-sampler-connections/
« on: June 12, 2017, 05:09:49 PM »mutec made a 3rd party flashram card expansion
mutec-net.com
mutec-net.com
« on: March 06, 2017, 08:48:23 PM »Posted by: chrisNova777
« on: August 24, 2016, 03:09:47 AM »http://www.mpchunter.com/s3000xl/akai-ib304f-profilter-filter-board/
« on: December 31, 2015, 03:13:06 PM »http://macintoshgarden.org/apps/akai-mesa-ii
Features:
« on: December 30, 2015, 01:29:51 PM »https://www.gearslutz.com/board/high-end/524068-harddrive-question-akai-s2000.html
« on: March 22, 2015, 06:58:46 PM »http://www.synthman.com/akai/300600.html
http://akai.mnx2010.nl
The S2000 offers the same superb audio quality and programming power of the S3000 Series with a new streamlined, easy-to-use interface. But that's just the beginning. Despite its amazingly low price, the S2000 includes a SCSI interface as standard, so you can connect an external hard drive or CD ROM drive without having to buy an extra upgrade kit. The S2000 also includes Akai's MESA software, which allows graphic programming and library management from the screen of a Macintosh computer.http://web.archive.org/web/19970215072550/http://akai.com/akaipro/S2000.html
default config (non-expanded)
Creating OS disks:
http://akai.mnx2010.nl/
editable with:
EXPANSION OPTIONS
• IB304F FILTER BANK
• MORE MEMORY
Akai kindly provided an extra memory SIMM, and this gave me an excuse to take the lid off the machine. Nearly everything is one large circuit board, and the SIMMs slots are easily accessible. SIMMs will only fit into their sockets the right way round, so there's no problem with accidentally reversing them, though you do have to take precautions against static electricity. Removing the lid is a simple matter of taking out five crosshead screws, and the whole procedure takes less than five minutes.Quote• EXTRA STORAGE
some suggestions for cdroms:
hp cd-writer 9600 series
yamaha crw3200sx
