Samplers => Hardware Samplers & MPCs => samplers - late 80s => Topic started by: chrisNova777 on November 19, 2015, 09:26:47 AM
Title: e-mu sp1200 (1987) sampling percussion
Post by: chrisNova777 on November 19, 2015, 09:26:47 AM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=2010.0;attach=4943;image)
WHAT IS IT?
messages.
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=2010.0;attach=2653;image)
Title: Re: e-mu sp1200 (1987) sampling percussion
Post by: chrisNova777 on March 03, 2017, 07:52:33 PM
(http://www.muzines.co.uk/images_mag/articles/sos/SOS_87_10_e-mu_sp1200_large.jpg)
(http://www.muzines.co.uk/images_mag/articles/sos/SOS_87_10_e-mu_sp1200_1_large.jpg)
E-MU SP1200 SPECIFICATIONS
Sampling rate:   26kHz
Word length:   12 bits
Inputs:   1 for sampling
Number of segments:   100
Number of songs:   100
Display:   backlit LCD
Post by: chrisNova777 on March 03, 2017, 07:55:01 PM
(http://www.muzines.co.uk/images_mag/articles/mt/MT_88_01_korg_dsm1___1_large.jpg)
E-mu Systems SP1200
Sampling Percussion
Limitations
Verdict
Post by: chrisNova777 on July 17, 2017, 06:49:15 AM
(http://www.muzines.co.uk/images_mag/scans/sos/sos_87_09/l/sos_87_09-35.jpg)
Post by: chrisNova777 on January 18, 2019, 01:49:14 PM
http://privateprogram.blogspot.com/2012/10/the-emu-sp-1200-as-digital-retrofuture.html
MdtJA&index=2
