Software => Modern DAW Software => Cubase (Steinberg/Yamaha) => Topic started by: chrisNova777 on December 12, 2014, 07:47:45 PM
Title: Cubasis VST v3.0 & v4.0 require win98,ME,2k,XP (no dongle required) (2002) *dl*
Post by: chrisNova777 on December 12, 2014, 07:47:45 PM
(http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=601.0;attach=827;image)
DOWNLOAD LINK : CubasisVST_v4.rar (http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=601.0;attach=711)  | Cubasis v4.0 Manual (http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=601.0;attach=585) |  Cubasis Loops CD* (https://www.adrive.com/public/Qrf2mJ/CubasisLoops.toast.bin)
*this cubasis loops cd is in macbinary format and must be extracted via stuffit expander for pc (http://my.smithmicro.com/stuffit-expander-windows.html), which will reveal a .toast file, the toast file can then be renamed to .iso and burned with any cd burning software, or mounted virtually using an app such as daemon tools lite (http://www.daemon-tools.cc/products/dtLite)
video title says cubase 3.0 but is actually cubasis vst 3.0
final update was released in 2002
appears to be based on the cubase vst 5.1 software code + not SX rewrite code
http://www.soundbeam.co.uk/downloads/desktop/installing-cubasis.pdf
http://www.amazon.co.uk/Steinberg-Cubasis-VST-3-0/dp/B00005T6AW
http://www.amazon.de/Steinberg-Cubasis-VST-4-0/dp/B00006LRUO
(http://av.watch.impress.co.jp/docs/20020415/dal01.jpg)
Manufacturer's Description
Similar to Cubasis Go! 3.0 Cubasis VST 3.0 but with many additional features such as 48 audio channels, 4 virtual sound sources (synthesizer, universal sound module, virtual bass, drum machine) and full MP3 support. Do it the way the professionals do. Cubasis VST gives you a complete music studio - in your PC. Up to 24 audio channels and 64 MIDI tracks, mixers, real-time effects, a virtual sound module and much more are waiting to be taken through their paces. The multimedia tutorial shows you how - in only a few minutes. Compose songs, edit, print scores, produce music videos and burns CD's. Cubasis VST lets you make your musical ideas a reality.
New in version 3.0:
48 audio channels
Full MP3 support
Look and feel
Multimedia tutorial
16 new effects - now even easier to use
Surround sound
Video software
WaveLab Lite 2.0 and much more
(http://av.watch.impress.co.jp/docs/20020415/dal02.jpg)
   Cubasis VST v3.0 r2
     At the time of writing, Steinberg have just released a minor update for Cubase VST's little PC brother, Cubasis VST. Revision 2 is a free 7Mb download from http://web.archive.org/web/20051026011247/http://service.steinberg.de/webdoc_ps_int.nsf/show/updates_applications_pro_pc_en and includes a selection of improvements and bug-fixes. Most prominent of the former is the incorporation of the same optimisations for Pentium III, Pentium 4 and AMD Athlon processors found in the full Cubase v5, while a shorter load time and working MIDI Clock support are also promised. Sam InglisCubase TipsIf you need to keep track of where you are in a Song, but it isn't practical to be sitting right in front of your monitor, then the SMPTE Time Display window (Show Big Time on the Windows menu) is your friend. As its name suggests, it's a window which shows the current Song time in large, easy-to-read characters. By default, the display is formatted in hours, minutes, seconds and frames -- but if you Option-click (on a Mac) or Control-click (on a PC) in the window, the current Song position in bars and beats will be displayed instead.
Folder Tracks can be a good way to keep your Arrange Window tidy when working on complex Songs. For example, if you start off building your track with either VST Instruments or external MIDI instruments, then bounce or record the Parts onto Audio Tracks, afterwards you may want to drag the no-longer-needed MIDI Tracks to a Folder Track, to make more room for working on the rest of the arrangement. Muting the Folder Track will mute all the Tracks inside it, to avoid confusion with the recorded Parts.
If you receive an error message telling you that No More Mixer Channels are available when you try to select a VST Instrument, one possible culprit is Propellerhead Software's Reason -- even if you don't own the full version, just installing the demo can be enough to cause the problem. The reason for this is that Cubase automatically assigns an audio channel for every one of Reason's 64 ReWire channels on startup, thereby running the risk of using up all of its available channels. You can download a patch from the Propellerhead web site (www.propellerheads.se) to alleviate this problem by limiting Reason to just 16 channels.
(http://av.watch.impress.co.jp/docs/20030818/creat1_5.jpg)
Title: Re: Cubasis VST v3.0 & v4.0 require win98,ME,2k,XP (no dongle required) (2002) *dl*
Post by: chrisNova777 on January 19, 2017, 09:18:51 AM
no dongle required - great place to start for newbies!
