Attach:
(Clear Attachment)
(more attachments)
Restrictions: 48 per post, maximum individual size 64512KB
Steinberg's most well known product is C*B***  (6):
Digital Performer is a program made by M*T* (4):
what was opcodes main product called V***** (6):
« on: March 03, 2019, 07:23:31 AM »
« on: January 30, 2019, 04:41:26 PM »
« on: January 20, 2019, 07:04:56 AM »
« on: January 18, 2019, 08:17:59 AM »
akai s612 sampler
The S612 captures sound.
FITTING IN
FRONT
THE SLIDER
BACK
CONCLUSION
« on: January 07, 2019, 11:08:13 PM »
« on: June 20, 2017, 12:02:09 AM »
THE NEED
THE SET-UP
EASY DOES IT
LOOPY TUNES
