Author Topic: Soundscape Mixtreme SS810-1 (1998)  (Read 10887 times)
« on: April 14, 2015, 06:06:54 PM »
http://www.pmotions.com/Public/PDFs/Pro%20Audio/Mixtreme.pdf
http://www.soundscape-digital.com/
http://www.soundonsound.com/sos/apr99/articles/mixtreme.htm
The Soundscape mixtreme PCI card has a completely different concept, as not only does it provide 16 channels of 24 bit digital input and output for your computer
 there’s also a super powerful 80MHz Motorola DSP (Digital Signal Processor) on board, running professional 24 bit digital mixing and real-time effects plug-ins (optional) originally developed for the award winning Soundscape SSHDR1-Plus DAW.
mixtreme comes with Multimedia drivers for Windows™ 95, 98 and NT4, allowing use with most PC
based MIDI/Audio sequencer and recording/editing sof
tware packages, or with Video Editing Systems like Adobe®Premiere™, In-Sync Speed R
azor or Ulead Media Studio.  ASIO drivers for Steinberg Cubase VST/24 and other ASIO compatible sof
tware like Emagic Logic Audio Windows are also provided.
Brief Specification
     MIXTREME
DSP Chip: Motorola 56301 80MHz for 24-bit mixing and real-time effects processing.
Internal Path: 24-bit.
I/O: 2 x TDIF 8-channel digital.
S/PDIF: optional (on daughterboard), providing 1 In and 1 Out.
Internal Sample Clock: 10kHz-50kHz.
MIDI: In, Out, Thru for locking to MTC (not yet implemented).
SS8IO-3:
A-D Converters: AKM 20-bit.
Input S/N Ratio: -97.5dB A-weighted.
Maximum Input Level: +3dBu (for full scale).
D-A Converters: AKM 20-bit.
Output S/N Ratio: -97dB unweighted.
Maximum Output Level: +3dBu.
Frequency Response: 30Hz-20kHz (-0.2dB).
Sample Rates: 44.1kHz (-27%) to 48kHz (+12%) with external clock, 44.1 or 48kHz with internal clock, 16kHz-48kHz with SuperClock input.
