Author Topic: Asus 486SV2G motherboards may require 5V CPUs  (Read 7224 times)
« on: September 05, 2015, 12:23:27 AM »
just to bookmark a note i found on the net:
https://groups.google.com/forum/#!topic/alt.comp.periphs.mainboard.asus/_eVsLLI7GTM
this may be correct or incorrect; not sure but:
The ASUS 4866SV2G motherboard does not support 3V CPUs like the Intel 486DX4/100MHz.
The 486SV2GX4 or PVI-486SP3 supports the 3V CPUs.
For the 486SV2G, you can upgrade your CPU to 486DX2/66MHz, AMD 486DX2/80MHz.
heres a list of the 3.3v cpus
that are probably not compatible (at least the ones made by AMD):
25MHz:
Am486 DX4-75   25 MHz   75 MHz   3.3 V   8 KiB WT
Enhanced Am486 DX4-75   25 MHz   75 MHz   3.3/3.45 V   8 KiB WB
33MHz:
Am486 DE2-66   33 MHz   66 MHz   3 V   8 KiB WT   1996(?)
Am486 DX4-100   33 MHz   100 MHz   3 V
Enhanced Am486 DX2-66   33 MHz   66 MHz   3.3/3.45 V   8/16 KiB WB
Enhanced Am486 DX4-100   33 MHz   100 MHz   3.3/3.45 V   8/16 KiB WB
40MHz:
Am486 DX4-120   40 MHz   120 MHz   3.3 V   8 KiB WT
Enhanced Am486 DX2-80   40 MHz   80 MHz   3.3/3.45 V   8 KiB WB
Enhanced Am486 DX4-120   40 MHz   120 MHz   3.3/3.45 V   8/16 KiB WB
http://web.archive.org/web/20030419164305/http://www.geocities.com/TheTropics/3337/sv2gx4.html
http://web.archive.org/web/20011221115041/http://www.ecst.csuchico.edu/~dranch/HARDWARE/asus-gx4.html
for cpu reference; see this page: https://en.wikipedia.org/wiki/Am486
(chart attached as image)
also benchmarks here: http://www.oldschooldaw.com/forums/index.php?topic=1227.0
« Last Edit: September 26, 2015, 06:22:15 AM by chrisNova777 »
