Author Topic: Cubase Audio XT v3.05 (1996/1997) for windows 3.1 + win 95  (Read 71420 times)
« on: August 24, 2014, 03:27:14 AM »
Confirmed working with windows 3.11 | confirmed working with win95
includes custom support for AWE32/64 cards under win3.1/win95
LINK **UPDATED** : CubaseXT.zip
the installer is also downloadable from ftp.steinberg.net (if u have a green steinberg parallel dongle key)
will only install on legacy windows systems such as windows 3.x or windows 95
the installer will have you select one of the following options of supported recording hardware during setup :
Windows Sound Card (pick this if u dont have any of the options below)
Digidesign Session 8
http://archive.digidesign.com/download/legacy/s8pc/
http://www.oldschooldaw.com/forums/index.php/topic,586
Digidesign Audio Media III
http://www.soundonsound.com/sos/1996_articles/jul96/digidesignsession.html
http://www.oldschooldaw.com/forums/index.php/topic,354
Yamaha CBXD3 / CBXD5
http://www.oldschooldaw.com/forums/index.php?topic=592
http://www.oldschooldaw.com/forums/index.php/topic,4135
http://www.oldschooldaw.com/forums/index.php/topic,592
Akai DR8 http://www.soundonsound.com/sos/1995_articles/aug95/akaidr8.html
Akai DR16 http://www.oldschooldaw.com/forums/index.php/topic,4451
Creamware Master Port
http://www.soundonsound.com/sos/1997_articles/oct97/creamware.html
http://www.oldschooldaw.com/forums/index.php/topic,4452
http://translate.google.com/translate?hl=en&sl=ru&u=http://www.muzoborudovanie.ru/equip/studio/seq/cubase305/cubase305.php&prev=search
readme ftp://ftp.steinberg.net/Archives/Cubase_preVSTversions/PC/Cubase30/cubas305.readme
http://www.datasheetarchive.com/files/intel/drg/pentiu~1/tools/cubase~1.htm
Tool: Cubase Audio XT/VST
Category: Digital Content Creation: Audio Editing/Mixing
Cubase Audio XT/VST* builds on the same sequencing, scoring and audio features from Cubase and Cubase Score* with VST native audio with Windows* 95 and supported soundcards. An XT version is also included for use with other hardware devices such as Digidesign's 882 interface, Yamaha CBX D3*, D5*, Akai* HDR-8, 16 and Creamware Masterport*. Custom Mixer* maps are included for total audio automation of levels, pans and EQ's on the specific hardware.
http://www.soundonsound.com/sos/1996_articles/jul96/steinbergcubase3.html
http://www.soundonsound.com/sos/1997_articles/nov97/cubasevst.html
the attached file is directly from the steinberg ftp and requires a cubase dongle (Serial or parallel) that will authorize the app.. any 3.x dongle should work aswell as this package was bundled with cubase 3.x
« Last Edit: February 16, 2023, 06:05:11 PM by chrisNova777 »
Re: Cubase Audio XT v3.05 (1996/1997) for win 3.1 + win 95
« Reply #1 on: November 19, 2016, 01:22:33 PM »
Important note!!!!!!
This PC 3.05 updater will update version 3.01, 3.02, 3.03, or 3.04 DIRECTLY
to version 3.05. You do NOT need to install any other updaters first.
There are three different 3.05 updaters - one each for Cubase (standard version),
Cubase Score, and Cubase Audio XT. Please ensure that you are using the correct
updater for the program type that you have installed!!!!
The updaters require a file named PATCHW.DLL to be present in the WINDOWS folder
of your system. This file has been copied to your harddisk during the initial
CUBASE setup procedure but might have been overwritten since then with another
version by another program愀 installer. In case you experience difficulties with
the updater, they might be related to this issue. Before calling Steinberg support,
you should download PATCHW.ZIP from our ftp-site as well, unzip it and copy it to
the WINDOWS folder of your PC.
Enjoy!
The Steinberg Team.
Bug fixes and more
Cubase Audio XT 3.05, Cubase Score 3.05, Cubase 3.05
Synchronization options added for MIDI, Audio and external time code (SMPTE/MTC).
A notification message appears whenever Cubase discovers that the sync between audio
and MIDI does not work properly.
Patch- and bank-name support for Creative Labs AWE Soundfonts (requires an installed
AWE32 or AWE64 card).
Remix of drum tracks turned the pan to the leftmost position. Fixed.
Num Lock when editing a value field has been always turned on. On some Notebooks and
Laptops this behaviour disables other underlying keys. A new switch in Cubase's INI
file allows setting the Num Lock behaviour.
When printing multiple copies the clef and key of the first staff on the first page of
following copies was missing.
Turning the Part Appearance to "Show Events" with group parts in the Arrangement did crash.
Fixed.
New key command (not explained in the manual): Ctrl+Shift+T on the Arrange window opens
an edit field allowing to set the track class by entering a number or the first letter
of the track class (except always 'x' for Mix track instead of 'm' and always 'space'
for Chord track instead of
'c'):
   1 = MIDI track
   2 = Drum track
   3 = Mix track
   4 = Audio track
   5 = Group track
   6 = Tape track
   7 = Chord track
New key command (not explained in the manual): Alt+Ctrl+Shift+R on the Arrange window
performs a Remix for the selected MIDI track using the Note numbers.
Real-time chord display in the key editor was blank when playing the same chord again.
The chord display in the score editor did only show the chord when moving the mouse
simultaneously. Both fixed.
The Graphical Mastertrack Editor did not show a rubber band when selecting with the mouse.
Fixed.
Loading Songs created with Cubase for Atari or Mac did sometimes create a GPF. Fixed.
Recording Audio in external sync did freeze the system when the time code stopped.
With "Chase events" turned on, Part Parameter have been sent accidentially to the first
device.
Sound card audio
Sound card version has improved timing.
If both, "Prerecord" and "Preroll", are inactive in the Metronome settings, Cubase will not
record any audio material.
Fix for the Digital Audio Labs CardD+ and Digital Only Cards driver's inability to work with
"Record while playback" (full-duplex) together with Cubase. Please mind, that the number of
audio channels for input and output have to be the same when "Record while playback" is
turned on. Digital Audio Labs might remove this limitation in a future update of the
CardD+ device driver for Windows.
Note: The CardD+ or Digital Only Card cannot mix the input signal with the output signal
when performing a full-duplex recording. You will only hear the playback of existing
recordings. You have to turn off "Record while playback" in the Audio Hardware Settings
inside Cubase, i.e. disable full-duplex operation, in order to hear the incoming signal
while recording. If you want to monitor your new recording and hear the existing recordings
you have to use an external mixing desk for this purpose.
Step input in polyphonic voices didn't work correctly for voice other than voice one. Fixed.
Staff Separators are attached to the first line (staff) in a Grand Staff.
If you Hide this first line, the staff separator disappears. Fixed.
When using Polyphonic Voices, if a note is set to Voice 2, 3 or 4, Move To Staff is not
possible UNLESS: the note is first set to Voice 1. Fixed.
Cubase 3.05
The manual explains a function called "Make Chords" in Score Editor's "Do" menu. This
function was missing and it is now available.
Cubase Audio XT 3.04, Cubase Score 3.04, Cubase 3.04
Cubase 3.02/3.03 did not allow to print out the score notation. (Cubase Score and Cubase
Audio did not have this problem.)
[ALT]-[D] in the Audio Pool window performs the "Duplicate" function as described in the
manual.
Data can be saved to a disk with more than 2 GB of free space. Before a "Not enough space
on the destination drive" message was displayed and it was not possible to save the data
on the disk.
Drum Editor showed sometimes multiple hi-lited instruments after selecting another
instrument. Though only the last selected instrument was actually selected.
Yamaha CBX-D3/D5
Some hardware settings were not saved with the songs or the setups. "Sync Mode" and some
Input/Output settings for the CBX-D5 had to be set manually for each session.
Pre-listen to some files in the Audio Pool or Editor might have crashed the computer if
the files on the hard disk were too fragmented.
Destructive editing functions in the pool (Normalize, Pitch Shift, etc.) did not work
correctly when the "Write Behind Caching" in Windows 95 or the "32-bit Disk-Access" in
Windows 3.11 was enabled. (The resulting audio file did only playback for a fraction of
a second, even though the file was entirely and correctly processed.)
Cubase Audio XT 3.03, Cubase Score 3.03, Cubase 3.03
With sound card audio stereo recordings used two playback channels. While channel 1 played
back a stereo recording, any recording on channel 2 was muted.
Support for Yamaha CBX-D3/D5 added
Cubase Audio XT 3.02, Cubase Score 3.02, Cubase 3.02
Monitor Window look changed.
Corrupted Style names when saving Songs fixed.
Monitor did not reflect possible changes when loading a new song.
GM / GS / XG Editor did not send proper sysex data on slow machines.
When loading a Song or and Arrangment containing invalid Audio events
(no reference in the pool) in ghost parts could result in a GPF. Fixed.
Closing the IPS under certain circumstances did bring up another application.
The last used mode of the Logical Editor is saved in the Cubase INI file.
Directory names and file names containing country dependant characters (e.g. �...�) are now
recognized by Cubase.
Printing: Note stems and Bar lines are thickened for better readability.
Import MIDI File Type 0 Merge Mode: Failed when first track was empty (no part). Fixed.
Chord Symbol "half diminished" corrected.
Windows 95 only: Windows cursors enabled
Printing and Exporting Scores: Randomly appearing dithered bar lines corrected.
New "Confirm Record" dialog box. Allows direct input of new name for the recording and rename it,
deletion, or keeping.
Edit Solo shortcut [A], does now function inside the audio editor.
Sound card Hardware Settings will retain the "Sample Position" sync between sessions. Previously
after each restart of Cubase "DMA Blocks" were selected.
Sound card audio
Recording files may be now renamed immediately after the recording and/or later.
The speaker icon in the audio editor allows auditioning of the audio material.
Session 8 and AudioMedia III
FX-Send of each channel and masters is saved in the song.ALL.
MIDI timing and restart problems on cycle point changes w/o audio-tracks fixed.
Cubase Audio XT 3.01, Cubase Score 3.01, Cubase 3.01
Transpose/Velocity dialog, Transpose value: Scrolling to positive and after that to negative, the
negative values started from 254 etc.
Recording of audio tracks during ext. synch enabled (did not record at all or crashed)
Bug fixed which resulted in occasional clicks at the end of audio files when used on sound cards
Bug fixed which resulted in audio recordings appear in the pool but not in the arrangements
(Record bug: Record from bar 1 bis 18; no recording between bar 18 to 36; record starts again at
bar 36...)
Draw speed of parts on the Arrange window increased.
Inverted Audio parts display their wave form.
GPF when an Arrangement is discarded on random occasions has been fixed.
Launching Cubase in a low memory situation did not display "Not enough Memory" but did result in
a GPF. Fixed.
Audio Media III
If the AMIII doesn't init successfully, there is no sync for cubase available.
If the user changes the interface selection in the hardware dialog of the audio menu, he must
exit cubase and launch it again. If there are problems to set the interface to AMIII within the
dialog, you can edit the adevice.ini of the cubaseda\audio\aumed folder:
Interface=AudioMedia PCI
Note: there are new am3_dsp.dll, vdaed.vxd and sesthunk.dll from digidesign available!
Mros: Mr_mmwin.dll
Version 2.02
Via SetupMME renamed and inactivated Ports were active in Cubase. Fixed.
Version 2.03
Creative SB AWE32 User SoundFont Bank support added.
Crash with Roland PCMCIA Card SCP-55 Win95 driver Vers. 4.00.002. after quitting Cubase
(Notebooks only!). The Windows MME reset is now excluded for the SCP-55 MIDI Input to solve this
problem.
Mros: Mr_mmc.dll
Version 2.00
The tape is now located when the sequencer is located and not when the user hits play.
Cubase and HP 5L Laserjet printer
I have successfully used a HP-5L laserjet printer with Cubase Score
under Windows 95 without any apparent problems. The PC always sees the
key (even when the printer goes into "sleep mode") and prints out OK.
This is how to do it:
* Set the LPT-1 communication mode of the PC to normal/compatible in
  your PC BIOS.
* Boot the PC and run the HP-5L setup for the drivers.
* Select custom setup and select PCL driver (NB that the default will
  probably be Host **don't accept this**). Accept all the other
  defaults.
(When you install the software for the HP-5L you can choose two drivers
Host based or PCL. The host based driver uses the PC to process print
data. The PCL driver uses the printer to process printing data. If you
use the host based driver staves print out without lines !).
* Note that you still have to pay attention to the Windows 95 printer
  notes from Steinberg i.e. spool settings must be set to RAW for
  multiple page print out to work properly.
If you follow these instruction it all seems to work OK
with Cubasis/Cubase Score 2.03/Cubase Score 3.0/Cubase Audio 3.0.
NB I was using the following HP drivers:
Installation disc set 1.01
PCL driver version G 1.20
Status Window version B 3.16.10
Cubase and Mark of The Unicorn MTP II MIDI Interface
When recording a Sys-Ex dump and open up the List Editor to double-click on the dump's song
position and move it (no more than say 48 ticks earlier); go into MIDI Mixer and record while
stopped one keypress for the TG55 front panel; take the MIDI Mixer part into List Edit to
duplicate this keypress about 192 ticks later, then a GPF may occur.
Solution: Go into Control Panel/Multimedia (Properties)/Advanced and expand MIDI Devices and
Instruments. Select Properties for any one of the MTP Out Ports. Click Settings... This should
bring up a dialog box to set the Base Address and IRQ; but it also has a number of Options, one
being:
Allow multi-tasking during "Sys-Ex"
This is normally "checked" when first set up. Uncheck it, and it fixes the problem.
Crackling and glitching audio and VGA device drivers
The following text was not created by Steinberg, it was taken "as is" from Greg Hanssen of Zefiro
Acoustics.
   A good number of VGA card manufacturers are squeezing out a few extra
points on their winbench scores by locking up the PCI bus.  This is fine
for graphics and most systems on the PC (hard disks and such) don't even
notice the problem.... Unfortunately this can hurt the audio system in
a big way.
   Most audio cards use ISA/DMA to trickle samples over the bus one word
at a time.  Even PCI cards such as the AMIII can be hurt by this problem
because they trickle the data over the bus in tiny PCI transfers.  When
another device illegally locks up the bus for more than 1/88200th of a
second, there's a good chance you will lose audio samples resulting an a
glitch in the recording or playback.
   How do you know if you're having this problem?  Try opening up your
favorite wave editing program, loading a wave file and hitting the play
button.  While the audio is playing, grab the top of the window (assuming
it is not maximized) and repeatedly pick it up and drag it to another
location on the desktop.  On a soundblaster compatible card, the audio
will glitch and pop while you drag the window.  On a ZA2 card, there is
a 50/50 chance the audio will swap L/R channels after such a glitch.
On an adb card, not only can the right and left channels swap, but there
is also a good chance the audio will be left in a glitchy mode that makes
the audio repeatedly jump channels resulting in a high pitch scratchy
noise.
   At this point in the discussion, I would like to stress that this is NOT
(I repeat NOT) the fault of the soundcard!  This is not even the fault
of the VGA card... it is in fact the fault of the VGA driver.  If you do
not experience any glitching or distortion then you can probably ignore
the rest of this post!  I've heard that the VGA drivers supplied by
Microsoft (verses the drivers supplied by the VGA manufacturer) do not
suffer from this problem.
   I think Matrox was the first to play with this, but it doesn't really
matter because most high performance VGA accelerator cards for the PCI
bus are doing the same thing now.  When a number of graphics acceleration
operations need to be performed, these commands are sent from the VGA
driver to the VGA card over the PCI bus.  The VGA chipset has a built in queue
that is capable of holding several accelerator commands.  Normally the
driver checks a status bit on the VGA card to tell if this queue is full or not.
If the queue is full, the driver waits for the queue to have a free space
before sending the next command.  Matrox discovered (and everyone soon
followed) that you could increase VGA performance by NOT CHECKING THIS
STATUS BIT!!!!!  What happens when you write blindly to a full queue of
commands on the VGA card?  The bus hangs... The bus master has started a
PCI transaction, but the target (the VGA card) can't accept the data yet
because it has no place to put it.  As soon as the VGA card has room for
the data, then the transaction can complete... but until that time the PCI bus
is completely locked up.  No PCI or ISA transactions can happen.  This can
take a long time (40 or more audio cycles) if the current VGA operation is
a huge BITBLT on a 24bit screen...  A 256 or 512 bit FIFO just ain't gonna
cut it.
   The only acceptable solution to this problem is to put the queue check
BACK into the VGA driver.  I have been discussing this problem with some
of the engineers at Matrox and Tseng labs and have some solutions for
you!
   Tseng labs has released a new version of their ET6000 VGA driver that
behaves nicer to the PCI bus. This driver is now trickling down to the
STB and Hercules products that use the ET6000 chip.  For the Hercules
Dynamite 128 card, there is a new driver on the Hercules BBS (not web
page... don't ask me) called DV95112  (Version 1.12)  Using this driver,
you need to add a special switch in your system.ini file.  Under the
heading [Hercules] there is a line that reads "Optimization=0"  you will
need to set this to "Optimization=1"... ta da, problem fixed.
   It turns out that Matrox has ALWAYS had a hidden back door switch to
enable this check in the VGA driver.  If you are using the Matrox
Millennium, you will need to add the following lines to your system.ini file:
[mga.drv]
PCIChipset=1
This almost fixes the problem completely.... you will also need to disable
the "Use PowerGDI acceleration" feature in the Advanced Matrox setup
(Control Panel->Display Properties->MGA Settings->Advanced->Performance)
ta da... problem fixed.
Unfortunately there are other VGA makers (ATI, Number 9...) who have not
acknowledged this problem (not that Matrox or Tseng has formally done so
either).  And we as users, software manufacturers or hardware
manufacturers need to get the word out that this is a VGA problem
and not a DMA problem!!!!!!  We need to drill it through the heads of
the VGA card makers that they can't get away with this B.S. without at
least having an OPTION to make the driver behave appropriately.
Have you ever been told to turn the VGA acceleration off???   or to reduce
the size of your VGA screen???   or reduce the color depth???
THESE ARE NOT ACCEPTABLE SOLUTIONS!!!
  Call your VGA manufacturer and tell them they need to fix the problem!
(You will probably need to get beyond Joe Tech Support, because he
probably doesn't know anything about this... please inform him!)
This information has been brought to you by Greg Hanssen (hanssen@zefiro.com)
copyright 1996 Zefiro Acoustics.
pro audio equipment supported by cubase audio XT (1997)
« Reply #2 on: November 19, 2016, 03:58:02 PM »
list of equipment mentioned in the cubase setup files
akai mpc60 http://www.oldschooldaw.com/forums/index.php?topic=3144
akai dr8 http://www.oldschooldaw.com/forums/index.php?topic=867.0
akai dr16 http://www.oldschooldaw.com/forums/index.php?topic=4451.0
akai s612 http://www.oldschooldaw.com/forums/index.php?topic=2646
alesis d4 http://www.oldschooldaw.com/forums/index.php?topic=1429
alesis midiverb http://www.oldschooldaw.com/forums/index.php?topic=3431.0
alesis quadraverb http://www.oldschooldaw.com/forums/index.php?topic=1451
casio cz-3000 http://www.oldschooldaw.com/forums/index.php?topic=2379
creative labs AWE32 http://www.oldschooldaw.com/forums/index.php?topic=624.0
digidesign 882 http://www.oldschooldaw.com/forums/index.php?topic=355
digidesign audiomedia III http://www.oldschooldaw.com/forums/index.php?topic=154.0
digitech dsp128 http://www.oldschooldaw.com/forums/index.php?topic=1453
digitech dsp256 http://www.oldschooldaw.com/forums/index.php?topic=1514
dmc mx8 http://www.oldschooldaw.com/forums/index.php?topic=2374
emu morpheus http://www.oldschooldaw.com/forums/index.php?topic=2139
emu procussion http://www.oldschooldaw.com/forums/index.php?topic=1908
emu proformance 1 http://www.oldschooldaw.com/forums/index.php?topic=2558
emu proteus fx http://www.oldschooldaw.com/forums/index.php?topic=2483
emu proteus 1 http://www.oldschooldaw.com/forums/index.php?topic=1921
emu proteus 2 http://www.oldschooldaw.com/forums/index.php?topic=4429.0
emu proteus 3 http://www.oldschooldaw.com/forums/index.php?topic=4430.0
emu vintage keys http://www.oldschooldaw.com/forums/index.php?topic=1909
emu vintage keys pro http://www.oldschooldaw.com/forums/index.php?topic=1909
emu emax http://www.oldschooldaw.com/forums/index.php?topic=3139
ensoniq sq80 http://www.oldschooldaw.com/forums/index.php?topic=2183
ensoniq VFX http://www.oldschooldaw.com/forums/index.php?topic=1476
ensoniq esq1 http://www.oldschooldaw.com/forums/index.php?topic=2303
ensoniq sd1 http://www.oldschooldaw.com/forums/index.php?topic=1903
fostex dcm100 http://www.oldschooldaw.com/forums/index.php?topic=4254
fostex fos280 http://www.oldschooldaw.com/forums/index.php?topic=4001.0
kawai k1 http://www.oldschooldaw.com/forums/index.php?topic=2247
kawai k3 http://www.oldschooldaw.com/forums/index.php?topic=2850
kawai k4 http://www.oldschooldaw.com/forums/index.php?topic=2361.0
kawai k5 http://www.oldschooldaw.com/forums/index.php?topic=2563.
kawai gmega http://www.oldschooldaw.com/forums/index.php?topic=2551
kawai xd5 http://www.oldschooldaw.com/forums/index.php?topic=2587
kmx 8x8 http://www.oldschooldaw.com/forums/index.php?topic=2388
kmx 15x16 http://www.oldschooldaw.com/forums/index.php?topic=2389
korg 01w http://www.oldschooldaw.com/forums/index.php?topic=1468.0
korg 03rw http://www.oldschooldaw.com/forums/index.php?topic=2857.0
korg 05/rw http://www.oldschooldaw.com/forums/index.php?topic=2315
korg sdd3300 http://www.oldschooldaw.com/forums/index.php?topic=4151
korg X5 http://www.oldschooldaw.com/forums/index.php?topic=2978
korg drv2000 http://www.oldschooldaw.com/forums/index.php?topic=1460
korg dw6000 http://www.oldschooldaw.com/forums/index.php?topic=2570.0
korg dw8000 http://www.oldschooldaw.com/forums/index.php?topic=2723.0
korg EX800 http://www.oldschooldaw.com/forums/index.php?topic=4131
korg wavestation http://www.oldschooldaw.com/forums/index.php?topic=1471
korg wavestation AD http://www.oldschooldaw.com/forums/index.php?topic=4015
korg wavestation SR http://www.oldschooldaw.com/forums/index.php?topic=2360.0
korg m1 http://www.oldschooldaw.com/forums/index.php?topic=2178.0
korg t1 http://www.oldschooldaw.com/forums/index.php?topic=3170.
korg t2
korg t3 http://www.oldschooldaw.com/forums/index.php?topic=2192.0
korg m3r http://www.oldschooldaw.com/forums/index.php?topic=2819
kurzweil k1000 http://www.oldschooldaw.com/forums/index.php?topic=1922
kurzweil k2000 http://www.oldschooldaw.com/forums/index.php?topic=4096
lexicon lxp5 http://www.oldschooldaw.com/forums/index.php?topic=3172.0
lexicon lxp15 http://www.oldschooldaw.com/forums/index.php?topic=1365.0
lexicon lxp5II http://www.oldschooldaw.com/forums/index.php?topic=1366
lexicon lxp1 http://www.oldschooldaw.com/forums/index.php?topic=1507
lexicon pcm 70 http://www.oldschooldaw.com/forums/index.php?topic=1436
motu midi mixer 7s http://www.oldschooldaw.com/forums/index.php?topic=2365
oberheim matrix 6 http://www.oldschooldaw.com/forums/index.php?topic=1581
oberheim matrix 1000 http://www.oldschooldaw.com/forums/index.php?topic=1919
oberheim ob8 http://www.oldschooldaw.com/forums/index.php?topic=4432.0
oberheim xpander http://www.oldschooldaw.com/forums/index.php?topic=4235
peavey dpm3 http://www.oldschooldaw.com/forums/index.php?topic=3448
quasimidi quasar
roland soundcanvas
roland spd8 percussion pad http://www.oldschooldaw.com/forums/index.php?topic=4398.0
roland sc55 http://www.oldschooldaw.com/forums/index.php?topic=2109
roland d5 http://www.oldschooldaw.com/forums/index.php?topic=3163
roland d10 http://www.oldschooldaw.com/forums/index.php?topic=2063
roland d20 http://www.oldschooldaw.com/forums/index.php?topic=2177
roland d50 http://www.oldschooldaw.com/forums/index.php?topic=1518
roland d70 http://www.oldschooldaw.com/forums/index.php?topic=2102
roland d110 http://www.oldschooldaw.com/forums/index.php?topic=1426.
roland d550 http://www.oldschooldaw.com/forums/index.php?topic=2475
roland mt32 http://www.oldschooldaw.com/forums/index.php?topic=2398
roland juno1/2 http://www.oldschooldaw.com/forums/index.php?topic=1536
roland juno106 http://www.oldschooldaw.com/forums/index.php?topic=1421
roland jx8p http://www.oldschooldaw.com/forums/index.php?topic=1390
roland mks20 http://www.oldschooldaw.com/forums/index.php?topic=2554
roland mks50 http://www.oldschooldaw.com/forums/index.php?topic=1536
roland mks80 http://www.oldschooldaw.com/forums/index.php?topic=2040
roland mks70 http://www.oldschooldaw.com/forums/index.php?topic=4133
roland r8 http://www.oldschooldaw.com/forums/index.php?topic=2279
roland r8m http://www.oldschooldaw.com/forums/index.php?topic=2101
roland u110 http://www.oldschooldaw.com/forums/index.php?topic=3152
roland u220 http://www.oldschooldaw.com/forums/index.php?topic=2856.0
roland jv30 (1991) http://www.oldschooldaw.com/forums/index.php?topic=2845
roland jv80 http://www.oldschooldaw.com/forums/index.php/topic,6027
roland jv90 http://www.oldschooldaw.com/forums/index.php?topic=2300.0
roland jv880 http://www.oldschooldaw.com/forums/index.php?topic=1415
roland jv1000 http://www.oldschooldaw.com/forums/index.php?topic=5159.0
roland jv1080 http://www.oldschooldaw.com/forums/index.php?topic=2837
roland jd800 http://www.oldschooldaw.com/forums/index.php?topic=1420
roland jd990 http://www.oldschooldaw.com/forums/index.php?topic=1416
roland RAP10 sound card http://www.oldschooldaw.com/forums/index.php?topic=652
roland rd1000 http://www.oldschooldaw.com/forums/index.php?topic=4257.0
roland sbx 80 (sync box) www.oldschooldaw.com/forums/index.php?topic=2272
sequential cirtcuits sixtrak http://www.oldschooldaw.com/forums/index.php?topic=2024.0
sequential circuits prophet http://www.oldschooldaw.com/forums/index.php?topic=1843.0
tascam mm1 http://www.oldschooldaw.com/forums/index.php?topic=902
tc electronic tc2290 http://www.oldschooldaw.com/forums/index.php?topic=4152
yamaha dmp7 http://www.oldschooldaw.com/forums/index.php?topic=2505
yamaha dx7ii http://www.oldschooldaw.com/forums/index.php?topic=1546.0
yamaha sy77 http://www.oldschooldaw.com/forums/index.php?topic=1427
yamaha tx802 http://www.oldschooldaw.com/forums/index.php?topic=2827
yamaha tx7 http://www.oldschooldaw.com/forums/index.php?topic=2334
yamaha tx81z http://www.oldschooldaw.com/forums/index.php?topic=2242.0
yamaha v50 http://www.oldschooldaw.com/forums/index.php?topic=2565
yamaha rx7 http://www.oldschooldaw.com/forums/index.php?topic=2470
yamaha rx8 http://www.oldschooldaw.com/forums/index.php?topic=3162
yamaha rx5 http://www.oldschooldaw.com/forums/index.php?topic=2562.0
yamaha tg55 http://www.oldschooldaw.com/forums/index.php?topic=2408.0
yamaha sy55 http://www.oldschooldaw.com/forums/index.php?topic=2408.0
yamaha sy22 http://www.oldschooldaw.com/forums/index.php?topic=1907
waldorf microwave http://www.oldschooldaw.com/forums/index.php?topic=1918
yamaha tg55, yamaha tx81z, alesis d4, akai s612,  AWE32 card, e-mu procussion, proteus1, alesis midiverb, juno 1, juno 2, juno 106, roland u110, roland jv880, roland r8,
« Last Edit: February 14, 2019, 09:29:57 AM by chrisNova777 »
Mixermap
Re: Cubase Audio XT v3.05 (1996/1997) for win 3.1 + win 95 [DL]
« Reply #3 on: August 09, 2017, 05:44:33 AM »
If you want to try it out but don't have a PC with Windows 3.1 handy
Here is a full DosBox installation of Win 3.11 AND Cubase Audio XT 3.05
It is set up to work with DosBox's SoundBlaster emulation and it's ready to go.
MIDI data can be entered in the Key and Drum editors and played back by the emulated SB.
Have not tested yet how to connect a MIDI keyboard or how to get audio into the emulator as I have only used DosBox for games so far...
Your help would be much appreciated :)
Unzip the CBAXT305 folder and all its contents onto your hard drive (possibly root of C:).
Run the file "00-Start.bat"
Follow the on-screen instructions.
NOTE: I AM NOT RESPONSIBLE FOR ANY DAMAGE CAUSED BY USING THIS.
IT WORKS PERFECTLY ON MY SYSTEM: Core i5 / 8GB Ram / Windows 10 64bit.
PS.: I did not create the DosBox/Win3.11 setup, I downloaded it already made.
What I did is to make the whole installation portable (you don't need DosBox installed on your system), install CBAXT and optimise it, create the splash screen and the batch file to start the whole emulation to make it easy for people who have never used Dosbox.
« Last Edit: February 14, 2019, 09:32:09 AM by chrisNova777 »
« Reply #4 on: February 12, 2019, 04:41:16 PM »
28th of April 1995
================== Studio module drivers ====================
The current versions of the Studio module, at this date, are:
PC: 1.00 r5
Atari: 1.06c
Some of the drivers need the lastest Studio version.
The list is sorted alphabetically. It contains drivers made by Steinberg and
others made by some users (made on the Atari, but PC compatible).
360 Systems (folder 360_SYST)
   8x8 Midi patch bay (8_8PATCH.DEV)
   Audiomat (AUDIOMAT.DEV)
Akai (folder AKAI)
   Mb 76 (MB_76.DEV)
   PEQ 6 (PEQ_6.DEV)
   S-612 (S_612.DEV)
Alesis (folder ALESIS)
   D4 version 1.01 (D_4_101.DEV)
   D4 version 1.02 and above (D_4_102.DEV)
   MidiVerb 3 (MIDIVRB3.DEV)
   Quadraverb (QUADVERB.DEV)
   QuadraSynth (QUASYNTH.DEV)
Art (folder ART)
   DR 1 (DR1.DEV)
   Multiverb (MULTIVRB.DEV)
Bit (folder BIT)
   Master Keyboard (BIT_MAST.DEV)
Casion (folder CASIO)
   CZ-3000 (folder CZ_3000.DEV)
DMC (folder DMC)
   MX-8 (recent version) (MX_8.DEV)
   MX-8 (old version) (MX_8_MAN.DEV)
Emu (folder EMU)
   MPS (MPS.DEV)
   MPS+ (MPSPLUS.DEV)
   Procussion (PROCUSS.DEV)
   Proformance (PROFORMP.DEV)
   Proteus 1 XR Classic (PROT1XRC.DEV)
   Proteus 1 XR Pop (PROT1XRP.DEV)
   Proteus 1 Classic (PROT1_C.DEV)
   Proteus 1 Pop (PROT1_P.DEV)
   Proteus 2 (PROT2.DEV)
   Proteus 2 XR (PROT2XR.DEV)
   Proteus World (PROT3.DEV)
   Proteus World XR (PROT3XR.DEV)
   Protologic (PROTOLOG.DEV)
   Protologic XR (PROTOLXR.DEV)
   Proteus FX (PROT_FX.DEV)
   Vintage Keys (VINTAGE.DEV)
   Vintage Keys+ (VINTAGEP.DEV)
   Morpheus (MORPHEUS.DEV)
   Ultra Proteus (PROT_ULT.DEV)
Ensoniq (folder ENSONIQ)
   ESQ-1 (ESQ_1.DEV)
   ESQ SPM (ESQ_SPM.DEV)
   SD-1 (SD1.DEV)
   SQ-1 & SQr (SQ1.DEV)
   SQ-1+, SQr+, SQ-2 (SQ1_PLUS.DEV)
   SQ-80 (SQ_80.DEV)
   VFX (VFX.DEV)
Generic drivers (folder GENERIC)
   Universal download/upload (ANY_DUMP.DEV)
   Universal download/upload with bank display (GENERIC.DEV)
   General MIDI (GEN_MIDI.DEV)
Ibanez (folder IBANEZ)
   Reverb SDR-1000 (SDR_1000.DEV)
JL-Cooper (folder JLCOOPER)
   Patch bay MSB 16/20 (MSB16_20.DEV)
Kawai (folder KAWAI)
   K1, K1-r (K_1.DEV)
   K-3 (K_3.DEV)
   K-4 (K_4.DEV)
   K-5 (K_5.DEV)
   K-5 with old ROM version (K_5_SLOW.DEV)
   G-Mega (G_MEGA.DEV)
KMX (folder KMX)
   Patchbay 15x16 (KMX15X16.DEV)
   Patchbay 8x8 (KMX_8X8.DEV)
Korg (folder KORG)
   01-W, 01-Wr (01_W.DEV)
   01-W for use in sequencer mode (01_W_S.DEV)
   03-W (03_W.DEV)
   05-W (05_W.DEV)
   DRV-2000 (DRV_2000.DEV)
   DVP-1 (DVP_1.DEV)
   DW-6000 (DW_6000.DEV)
   DW-8000 (DW_8000.DEV)
   EX-800 (EX_800.DEV)
   I3 (I3.DEV)
   M1, M1r, M1ex (M_1.DEV)
   M3 (M_3R.DEV)
   SDD-3300 (SDD_3300.DEV)
   T1, T2, T3 (T1_T2_T3.DEV)
   WS (WS.DEV)
   WS-AD (WS_AD.DEV)
   WS-SR (WS_SR.DEV)
   X-5 (X_5.DEV)
Kurzweil (folder KURZWEIL)
   K-1000 (K_1000.DEV)
   K-2000 (K_2000.DEV)
   K-2000 that have a problem with bank-select messages (K_2000B.DEV)
   Micro Piano (MICROPIA.DEV)
   PX-1000 (PX_1000.DEV)
   Utility to retrieve K-2000 names: K2000NAM
Lexicon (folder LEXICON)
   LXP-1 (LXP_1.DEV)
   LXP-15 (LXP_15.DEV)
   LXP-15 version 2 (LXP_15V2.DEV)
   LXP-5 (LXP_5.DEV)
   PCM-70 (PCM_70.DEV)
Lists (folder LISTS)
   10 banks of 128 programs with MIDI bank select (L10_128.DEV)
   16 banks of 128 programs with MIDI bank select (L16_128.DEV)
   4 banks of 128 programs with MIDI bank select (L4_128.DEV)
   8 banks of 64 programs with MIDI bank select (L8_64.DEV)
   2 banks of 32 programs, program changes only (LIST2_32.DEV)
   2 banks of 64 programs, program changes only (LIST2_64.DEV)
   4 banks of 32 programs, program changes only (LIST4_32.DEV)
   1 bank of 100 programs, program changes only (LIST_100.DEV)
   1 bank of 128 programs, program changes only (LIST_128.DEV)
   1 bank of 32 programs, program changes only (LIST_32.DEV)
   1 bank of 50 programs, program changes only (LIST_50.DEV)
   1 bank of 64 programs, program changes only (LIST_64.DEV)
   folder MAKELIST : utility to create a "list" driver according to certain
   specifications. The created driver handles MIDI bank-select messages.
Miditemp (folder MIDITEMP)
   Patchbay PMM-88 (PMM_88.DEV)
Oberheim (folder OBERHEIM)
   Matrix 6 (MATRIX_6.DEV)
   Matrix 1000 (MAT_1000.DEV)
   OB-8 (OB_8.DEV)
   XPander (XPANDER.DEV)
Peavey (folder PEAVEY)
   DPM-3 (DPM_3.DEV)
   Multifex (MULTIFEX.DEV)
Roland (folder ROLAND)
   A-50 & A-80 (A_50_80.DEV)
   D-10, D-20 (D10_D20.DEV)
   D-10, D-20, D-110 with a sysex/tone approach (D10_TONE.DEV)
   D-110 (D_110.DEV)
   D-5 (D_5.DEV)
   D-50 (D_50.DEV)
   D-50 EX (D_50_EX.DEV)
   D-550 (D_550.DEV)
   D-70 (D_70.DEV)
   GP-8 (GP_8.DEV)
   GR-1 (GR_1.DEV)
   GR-50 (GR_50.DEV)
   JD-800 (JD_800.DEV)
   JD-990 (JD_990.DEV)
   Juno 1 & 2 (JUNO_1_2.DEV)
   JV-1000 (JV_1000.DEV)
   JV-1080 (JV_1080.DEV)
   JV-30 (JV_30.DEV)
   JV-80 (JV_80.DEV)
   JV-880 (JV_880.DEV)
   JV-90 (JV_90.DEV)
   JX-8 P (JX8_P.DEV)
   MKS-20 (MKS_20.DEV)
   MKS-50 (MKS_50.DEV)
   MKS-70 (MKS_70.DEV)
   MKS-80 (MKS_80.DEV)
   MT-32 (MT_32.DEV)
   PM-16 (PM_16.DEV)
   RD-1000 (RD_1000.DEV)
   R-8 (R_8.DEV)
   R-8M (R_8M.DEV)
   SBX-80 (SBX_80.DEV)
   SC-55 (SC_55.DEV)
   SC-88 (folder SC_88.DEV)
   SE-50 (SE_50.DEV)
   SPD-8 (SPD_8.DEV)
   U-110 (U_110.DEV)
   U-20 (U_20.DEV)
   U-220 (U_220.DEV)
   VP-70 (VP_70.DEV)
Sequencial Circuit (folder SEQUENTI)
   6 Tracks version 9 (6TRACK.DEV)
   6 Tracks version 4 (6TRACK_4.DEV)
   Multitrack (MULTITRK.DEV)
   Prophet-600 (PROPH600.DEV)
   Prophet-5 40 prog. (PROPH_5X.DEV)
   Prophet-5 120 prog. (PROPH_5.DEV)
   Prophet-8 (PROPHTT8.DEV)
   Prophet-10 (PROPHT10.DEV)
   Prophet VS (PROPH_VS.DEV)
Voyetra (folder VOYETRA)
   V-8 (V_8.DEV)
Waldorf (folder WALDORF)
   Microwave (MCROWAVE.DEV)
Yamaha (folder YAMAHA)
   DEQ-7 (DEQ_7.DEV)
   DMP-11 (DMP_11.DEV)
   DMP-7 (DMP_7.DEV)
   DX-11 (DX_11.DEV)
   DX-7 (DX_7.DEV)
   DX-7 II (DX_7_II.DEV)
   KX-88 latest ROM (KX88.DEV)
   ProMix 1 (PROMX1.DEV)
   QY-10 (QY_10.DEV)
   REV-5 (REV_5.DEV)
   REV-7 (REV_7.DEV)
   RX-7 (RX_7.DEV)
   SPX-1000 (SPX_1000.DEV)
   SPX-90 (SPX_90.DEV)
   SPX-90 II (SPX_90II.DEV)
   SY-22 (SY_22.DEV)
   SY-55 (SY_55.DEV)
   SY-77 (SY_77.DEV)
   SY-99 (SY_99.DEV)
   TG-33 (TG_33.DEV)
   TG-500 (TG_500.DEV)
   TG-500 other ROM type (TG_500_0.DEV)
   TG_77.DEV (TG-77)
   TX_7.DEV (TX-7)
   TX_802.DEV (TX-802)
   TX_816.DEV (TX-816)
   TX_81Z.DEV (TX-81Z)
Zoom (folder ZOOM)
   Zoom 9010 (ZOOM9010.DEV)
Offline foksadure
  • Stuck in 1997
« Reply #5 on: September 03, 2022, 04:38:54 AM »
does cubase audio 3 xt for windows work without a dongle?
It does if you use the cr*cked "cubase.386" file from the DOSBox version or the zip from Chris posted above, and put it in the C:\Windows\System\ folder.
No point in buying a full box without the dongle though, unless you're after the hardback manuals.
« Last Edit: September 03, 2022, 05:54:46 PM by foksadure »
Offline foksadure
  • Stuck in 1997
« Reply #6 on: September 03, 2022, 09:37:39 AM »
  • Seems there's an empty slot in the box where the dongle was
  • The installation files are already available in this thread or elsewhere
Ergo the floppies are useless to install and run Cubase 16bit.
Offline foksadure
  • Stuck in 1997
« Reply #7 on: September 03, 2022, 03:23:53 PM »
I'm sorry but you're being cryptic about what you're really after.
You can install Cubase XT, from the files posted here and there.
If you have the dongle, you can run it legit, like I am.
If you don't, there's the Cubase.386 cr*ck.
What's the point asking about floppies anyway?
« U.R. Card » means the serial (113000444) is on the User Registration Card, which one can see in the fourth picture your posted.  ;D
« Last Edit: September 03, 2022, 05:53:21 PM by foksadure »
Offline foksadure
  • Stuck in 1997
« Reply #8 on: September 04, 2022, 07:25:10 AM »
I get it know.  :)
--- Off-topic ---
Despite the ubiquitous Gotek USB adapters, floppies aren't dead yet.
https://www.theguardian.com/world/2022/sep/01/japan-digital-minister-declares-war-on-floppy-discs
Can't beat an old process that just works as expected. Everytime.
Offline foksadure
  • Stuck in 1997
« Reply #9 on: October 26, 2022, 02:42:21 AM »
Another source for the OG Cubase last 16bit version full installation CD-Rom:
https://archive.org/details/cubas305.r2
Steinberg Cubase 3.05r2 Installation-Disk
Steinberg Cubase 3.05 R2
Installations Disk original CD-Rom for Windows
Cubase 3.05
Cubase Score 3.05
Dongle required
