Author Topic: motu pc midi hardware updates (1997)  (Read 10759 times)
« on: November 18, 2016, 08:40:19 PM »
All of the software updates on this page can be used with Windows 95, Windows for Workgroups and Windows 3.1.
http://web.archive.org/web/19970113173301/http://motu.com/pages/DownloadWinConsoles.html
driver updates for
MIDI Timepiece AV,
MIDI Timepiece II,
MIDI Express PC,
MIDI Express PC Notebook,
PC-MIDI Flyer,
Pocket Express
Wayback Machine
Go
OCT   JAN   MAY
Previous capture   13   Next capture
1996   1997   1999
26 captures
17 Oct 96 - 15 Feb 06
 sparklines
CloseHelp
MOTU
Windows Updates for MOTU MIDI Interfaces
Windows Software Updates
All the downloads on this page are self-extracting files. To learn more about self-extracting files click here.
To determine if you should download an update, check the version number of the software you currently have. If it is lower than the versions shown here, you should download the updated version.
To check the version of a program, watch the startup screen when you run it or use the Help|About... menu. To check the version of a MIDI interface driver, use Control Panel to open its setup window. The setup window should display the driver's version number.
MIDI Timepiece AV
MIDI Timepiece AV Console and Driver (version 1.10/1.03, 465KB)
If you want the latest console and driver for your MIDI Timepiece AV, this download is all you'll need. This self-extracting file contains the latest version of the Windows console program and driver for the MIDI Timepiece AV. This update console adds Quicklock support as well as display improvements.
MIDI Time Piece II
MIDI Time Piece II console 1.1 and all drivers (511KB)
If you want the latest console and driver for your MIDI Time Piece II, this download is all you'll need. This self-extracting file contains the latest version of the Windows console program for the MIDI Time Piece II. This version of the console can be used with any MIDI Time Piece II Windows MIDI driver. Included in this download are the latest drivers for the 8-bit, 16-bit and PC Link types of MIDI Time Piece II expansion cards (the same drivers available elsewhere on this page). You do not need to download individual MTP II driver updates if you download this file.
Once you have retrieved and decompressed this download, read the README.WRI file and run SETUP.EXE.
To determine which of the following MIDI Time Piece II update to download click here.
MIDI Time Piece II (PC Link card) driver (version 2.03, 58KB)
This self-extracting file contains the latest version of the Windows MIDI driver for MIDI Time Piece II interfaces with PC Link cards. This driver will not work with any card other than the PC Link type. In this version of the driver, compatibility with 32-bit MIDI programs running on Windows 95 has been improved.
MIDI Time Piece II (16-bit card) driver (version 1.52, 41KB)
This self-extracting file contains the latest version of the Windows MIDI driver for MIDI Time Piece II interfaces with 16-bit cards. This driver will not work with any card other than the 16-bit type.
The version of the driver includes more reliable "networking" of two MIDI Time Piece units for access to additional MIDI ports. Compatibility with 32-bit MIDI programs running on Windows 95 has also been improved.
MIDI Time Piece II (8-bit card) driver (version 1.20, 30KB)
This self-extracting file contains the latest version of the Windows MIDI driver for MIDI Time Piece II interfaces with 8-bit cards. This driver will not work with any card other than the 8-bit type. This driver has been tested with 16- and 32-bit MIDI programs running on Windows 95.
MIDI Express PC
MIDI Express PC console 1.1 and all drivers (703KB)
If you want the latest console and driver for your MIDI Express PC, this download is all you'll need. This self-extracting file contains the latest version of the Windows console program for the MIDI Express PC. This version of the console can be used with any MIDI Express PC Windows MIDI driver. Included in this download are the latest drivers for the 8-bit and 16-bit MIDI Express PC expansion cards (the same drivers available elsewhere on this page). You do not need to download individual MIDI Express PC driver updates if you download this file.
To determine which MIDI Express PC update drivers to download click here.
MIDI Express PC (16-bit card) driver (version 2.13, 41KB)
This self-extracting file contains the latest version of the Windows MIDI driver for MIDI Express PC interfaces with 16-bit cards. This driver will not work with any card other than the 16-bit type.
This version of the driver contains MIDI input timing improvements. Also, connecting to the MIDI Express PC and saving/restoring of its internal state during each Windows session have both been made more reliable. Compatibility with 32-bit MIDI programs running on Windows 95 has been improved as well.
MIDI Express PC (8-bit card) driver (version 1.40, 36KB)
This self-extracting file contains the latest version of the Windows MIDI driver for MIDI Express PC interfaces with 8-bit cards. This driver will not work with any card other than the 8-bit type. This driver has been tested with 16- and 32-bit MIDI programs running on Windows 95.
MIDI Express PC Notebook update (console version 1.11 with driver version 2.03, 508KB)
This self-extracting file contains the latest version of the Windows console program for the MIDI Express PC Notebook. This version of the console can be used only with the latest version of the driver, which is included with this download.
This update corrects aspects of the previous version of the console that prevent it from running on Windows 95. Also, driver changes include improved compatibility with 32-bit MIDI programs running on Windows 95. Although it mainly addresses Windows 95 issues, this update is also recommended for Notebook users running Windows 3.1 or Windows for Workgroups.
PC-MIDI Flyer and Pocket Express
PC-MIDI Flyer/Pocket Express driver (version 1.03, 61KB)
This self-extracting file contains the latest version of the Windows MIDI driver for the PC-MIDI Flyer and Pocket Express. MIDI input and output has been made more reliable. Also, compatibility with 32-bit MIDI programs running on Windows 95 has been improved.
Home | Technical Support | Products | Downloads | MOTU Japan
Mark of the Unicorn, Inc.
Voice: (617) 576-2760      Tech Voice:(617) 576-3066
FAX: (617) 576-3609       Tech FAX:(617) 354-3068
e-mail:info@motu.com     Tech e-mail:techsupport@motu.com
Last Updated: November 5, 1996
