Author Topic: vision 3.5.x updates  (Read 6549 times)
« on: March 06, 2017, 09:01:23 PM »
June 1997--  Vision 3.5.4
This 3.5.4 release fixes the following problems:
-Choosing Edit>Capture Seq->Seq now correctly captures pan and volume events.
-Copying or "capturing" sequences now correctly pastes audio events.
-Performing edits in the Track Overview no longer causes "Illegal Write-Time" errors.
-Typing in note letters in the List Window now works.
Problems fixed in 3.5.2:
-Improved syncronization with DAE.
-Playing with the movie controller in the QuickTime window will now scroll SVP/VIS.
-SMPTE 29.97 drop frame in Internal sync mode no longer hangs at beginning of minutes when frame is dropped.
Features not discussed in printed documentation:
Setting Locators
Typing a number will no longer set an empty locator.  Instead,  option-number or option-click must be used.
Opening 3.0 Files with SMPTE Offsets
Because of some subtle changes and improvements in the way timing now works with Vision, SMPTE offsets for existing 3.0 files are automatically adjusted when opened. Although the new offset is moved back by 20 subframes, the actual synchronization of the sequence should play back as before.
-- http://web.archive.org/web/19970714024626/http://www.opcode.com/downloads/vision/mac/Vision3.5.4ReadMe.txt
July 1997-- Read Me notes for Vision 3.5.5b
This interim release fixes the following problems:
€ When punching in "on the fly," MIDI is now recorded successfully.
€ It is again possible to type in tempos with decimal values.
€ When using Wait for Note while in punch mode, typing Tab twice along with the Space bar initiates playback without entering record mode (as in previous versions).
€ With "Show All Fader Info" checked in a Console Window, the controller labels for vertical faders now function correctly when scrolling.
In addition, the following feature has been added:
€ In dialogs, if a number field is selected, typing Enter deselects it; typing Enter again OK's the dialog.
-- http://web.archive.org/web/19971108063919/http://www.opcode.com/downloads/vision/mac/Vision3.5.5bReadMe.txt
