Author Topic: Pro Tools Free 5.01 is supported on Mac OS 8.6 in addition to 9.x  (Read 9887 times)
« on: September 27, 2014, 10:57:46 AM »
http://archive.digidesign.com/compato/mainfreemac.html
http://web.archive.org/web/20050213222101/http://mixonline.com/products/review/audio_pro_tools_free/
Compatible CPU Models
Highly Recommended:
    Power Macintosh G4
    PowerBook G3
    Power Macintosh Blue & White G3
    iMac
Also Compatible (must be 200 MHz or higher):
    Power Macintosh Beige G3
    Power Macintosh 9600
    Power Macintosh 9500
Not Tested:
    G4 Powerbook
    iBook
Additional Computer Requirements
    System Software: Mac OS v8.6 & v9.x
    Pro Tools FREE will not work with Mac OS X
    Classic Mode under OS X is also not supported. If you have a dual-boot system with both Mac OS 9 and OS X, you must choose Mac OS 9 as your startup system either in your Startup Disk Control Panel or by holding down the Option key during startup to use Pro Tools FREE. Systems that can only boot in OS X cannot be used.
    Total System RAM: 128 MB minimum, 192 MB recommended (Additional RAM required for simultaneous use with MIDI sequencers. Virtual memory is not supported)
    CD-ROM drive for software install (not necessary for web installer)
    Monitor or Laptop, color required, minimum resolution of 1024 x 768 (note: early iBook models have a maximum screen resolution of 800 x 600, see also Mbox iBook)
    Opcode OMS v2.3.8 or higher (supplied on Pro Tools FREE CD-ROM or download here)
    Apple QuickTime v4.0 or higher (supplied on Pro Tools FREE CD-ROM or download here)
    Storage: A large, fast, hard drive for audio.
    For maximum performance, a dedicated ATA/IDE or SCSI disk drive(s), such as those qualified with Pro Tools LE, should be used.
make sure to install oms 2.3.8
+ at least quicktime 4 (if u have an older powerpc)
http://www.oldapps.com/mac/quicktime.php
http://en.wikipedia.org/wiki/QuickTime#QuickTime_4.x
Apple released QuickTime 4.0 on June 8, 1999 for Mac OS 7.5.5 through 8.6
On December 17, 1999, Apple provided QuickTime 4.1, this version's first major update
