Author Topic: Tascam 238 "syncaset" (1988?) 8 track cassette recorder  (Read 13172 times)
« on: May 28, 2017, 05:11:44 AM »
http://www.phys.tue.nl/people/etimmerman/recordingfaq/multi/tascam.html
https://www.rapmag.com/a/1990s/37-90/jan90/135-equipment-test-drive-the-tascam-238-syncaset
https://www.hifiengine.com/manual_library/tascam/238.shtml
A few years back, TASCAM developed a nearly pro-level cassette multitracker named the 238.  It's a 3U rackmount deck that looks nearly identical to a DA-38.  It doesn't have a built in mixer, like most cassette machines, and works very nicely as an intermediate step between a typical porta-studio and a full fleged project studio.  It's a great option for someone who wants to make very good sounding demos at a reasonable cost.  There was also a 4 track model (the 234) with the same options, although it looks quite differnt.  I suspect the 234 will sound even better than the 238, due to the larger track width.
The original model (238) utilized dbx noise reduction, and the later model (238S) used Dolby-S noise reduction.  The 238S is a much more desirable machine, and fetches an extra $50 to $100 in price on the used market.
So what makes this deck so special anyways?  Well, the 238 originally retailed for well over $1000.  It's retail price was higher than that of the Tascam 488.  Why?  Quality.  Think about it... the 238S (which is a stand alone tape deck) costs more than the mixer and tape deck combination of the 488mkII.  They must have cut some corners on the 488, and it's apparent in the sound quality.  In a head-to-head comparison between my used 238S and a friends new 488mkII, the sonic difference was uncanny.  There is much less hiss, crosstalk and wow and flutter on this deck than it's porta-studio cousin.  Just picking up a 238 and feeling it's weight gives a good idea of the build quality.  The transport is rock solid, keeping the wow and flutter to a minimum, and the Dolby-S seems to really keep things quiet without destroying the sound (like dbx can).
Divider
Features:
The 238 has all of the options of it's competition.  It uses soft-touch transport controls, has variable speed, and individual VU meters (12 segment LED) for each channel.  Other features include a shuttle wheel for fast searching forwards and backwards, manual punch in (with record button, or optional footswitch), automated punch in (with a few seconds of pre-roll, and a rehearsal option).  The 238 also features 2 locate points and a return to zero function.  The machine will also loop between the 2 locate points.  Finally, the noise reduction is switchable in groups of 4 tracks.
Divider
Syncronizing:
Another thing to mention is the term "Syncaset".  The 238S has a ribbon cable connector on the back labelled "Accessory 2" or "Serial I/F".  With this connector and a special syncronizing box (actually, there's several sync options), you can link two 238's together and have one be a master and the other a slave.  You still need to stripe a track on each deck, but this gives you 14 tracks of syncronized cassette recording.  The SMPTE timecode on track 8 tells the sync box what position the tape is on, and the sync box then sends a signal down the serial cable to keep the two decks locked together.  Very nice feature.  Unfortunately, TASCAM's price on the sync boxes is outlandish (almost $2K for the nicest model), so a used sync box is the only logical route.  (Especially since you can buy 2 used ADAT XT's for $2000 these days).
Here's all of the sync options for a Syncaset.  All of these prices are suggested retail, and they should be cheaper on the street.  Used will be much less.
MTS-30 - MIDI to FSK translator with Song Position Pointer - Provides MIDI sync for a single 238 via FSK or SPP, with the 238 acting as the master. The MTS-30 plugs into the the in/out on track 8. Then it has MIDI ports for integration into your MIDI setup. It seems to be  no different than any other MIDI/timecode interface. It doesn't utilize the 'Accessory 2' port. The retail price seems to be $275.
MMC-100 - MIDI Machine Control via Tascam Serial - works in much the same way as the MTS-30 but implements full MMC protocol. Thus the 238 can be the slave or the master. In addition to using track 8 for timecode, the 'Accessory 2' port is used to maintain correct tape speed during playback to maintain sync. If you bought one of these for each deck, and used a MMC-based tranport master (like a sequencer, for example) you could use both decks at the same time. It looks like the list price on this is $629.
ATS-500 - Two Machine Serial Synchronizer -  This box uses one 238 as a master and one 238 as a slave.  It has two 'Accessory 2' ports, one for each 238, and a bunch of I/O for the timecode on both machines, plus external timecode inputs (to sync both 238's with a video deck or master timecode generator for example). Doesn't have a MIDI interface built in. Keep in mind that you'll only have 14 total tracks, since the timecode uses one track on each machine. The list price is $999.
MTS-1000 - MIDIizer: Two Machine Serial Sync w/MIDI -  Again, using one 238 master and one 238 slave in a MIDI environment. This seems to be the ultimate solution to everything. It does everything the ATS-500 does, plus includes MIDI. Unfortunately the list price on these puppies is $2000.
Doin' it on the cheap - Buy a MIDI to SMPTE converter (like Opcode Studio 3).  Anything that reads and generates SMPTE timecode, and converts it to MIDI should work.  Hook this up to the master 238.  Then use an MMC-100 boxes, to give the slave 238 MIDI Machine Control. When you press play on the master, it will play the timecode on track 8, get converted to MIDI by the Studio 3 (or comparable SMPTE box), get sent to the MMC-100 as MIDI, and the MMC-100 will start the slave deck and keep it in sync.
Divider
Specifications:
So, here's the low-down on the machine's specs;  Taken straight from the user's manual.
Tape: C-30 to C-90 cassettes, Cr02 (Type II)
Track Format: 8-track, 8-channel, one-way record/play
Head Configuration:
8-channel permalloy record/playback head (x1)
8-channel ferrite erase head (x1)
Motors:
FG servo direct drive capstan motor (x1)
DC reel motor (x1)
DC ancillary motor (x1)
Tape Speed: 9.5cm/sec (3-1/2 IPS) +/- .5%
Pitch Control: +/- 12% of standard speed
Wow and Flutter:
0.04% WRMS (NAB weighted)
+/- 0.08% W. PEAK (DIN/CCIR/IEC/ANSI weighted)
Fast Winding Time: Approx 70sec with C-60
Recording Time: 15 minutes with C-60
Dimensions: (W x H x D): 480mm x 149mm x 345mm - 19" x 5-7/8" x 13-9/16"
Weight: 9.5kg - 20.94lbs
Line Inputs: (x8) 30K ohm, unbalanced RCA @ -10dBV (0.3V) nominal
Line Outputs: (x8) 470 ohms, unbalanced RCA @ -10dBV (0.3V) nominal
Channels: 8 channels of record/playback.  Noise reduction switchible in groups of 4 (1-4 / 5-8)
Bias/Erase Frequency: 85kHz +/- 5kHz
Equalization: 3,180 +35 u s
Frequency Response: 30 Hz - 16 kHz +/- 3.0dB
Signal to Noise Ratio (ref to 3% distortion):
52 dB (NR OFF, CCIR/ARM weighted, 400 Hz)
51 dB (NR OFF, not weighted 20 Hz to 20 kHz)
75 dB (NR ON, CCIR/ARM weighted, 1 kHz)
64 dB (NR ON, not weighted, 20 Hz to 20 kHz)
Distortion: Less than 0.8% at 400 Hz, 0VU, NR ON
Crosstalk (adjacent channels):  More than 70dB at 1 kHz, +10VU
Power Requirements:
USA / Canada:  120 VAC, 60 Hz
U.K. / Australia:  240 VAC, 50 Hz
Europe: 230 VAC, 50 Hz
Power Consumption: 51 Watts
Re: Tascam 238 "syncaset" (1988?) 8 track cassette recorder
« Reply #1 on: July 16, 2017, 12:00:29 PM »
« Reply #3 on: December 30, 2018, 02:26:05 AM »
