Author Topic: studio vision 3.5 original cd download  (Read 10349 times)
« on: July 31, 2017, 02:20:26 PM »
http://www.mediafire.com/file/1o82883oyll637w/Studio+Vision+Deluxe.toast
this is from 1997, so is suited for use installing on macintosh machines from the mid to late 1990s
as well as beige G3 / B+W G3 + Sawtooth G4 macs running mac os 8.x/8.6
« Last Edit: November 03, 2018, 10:22:27 AM by chrisNova777 »
Re: studio vision 3.5 original cd download
« Reply #1 on: January 31, 2019, 03:45:13 PM »
https://www.sweetwater.com/insync/studio-vision-quicktime-lockups/
Studio Vision and QuickTime Lockups
By Sweetwater on Apr 9, 1998, 12:00 AM
Like
+1
Tweet
We’ve had quite a few users who’ve been having system lock up problems when opening Studio Vision 3.5.6 during the initialization of Quick Time. The solution is to simply increase the preferred size of Studio Vision in the “get info” screen by a couple of megabytes. If you can set it to 12,000k it will work great.
Note: Increasing the preferred memory usage of most Mac applications can make them run faster and more reliably
« Reply #2 on: August 02, 2019, 12:23:56 AM »
https://web.archive.org/web/19971014205303/http://www.scvlondon.co.uk/newsset.htm
VISION 3.5
MIDI and audio recording and sequencing for music and media
You already know that Vision is an awesome MIDI sequencer, but did you know that it's also an audio powerhouse? Introducing Vision 3.5, digital audio at an affordable price. Not only have we packed 3.5 with new features and flexibility, for a limited time we're also offering a Deluxe CD Edition that builds on Vision's new audio capabilities. This special bundle brings you a virtual rack full of effects like Reverb, EQ, Compression and more! Read on to find out more about this truly spectacular music environment.
QuickTime Support
With version 3.5, we built the QuickTime movie window right into Vision. Now you can use Vision to directly read and write QuickTime audio and music (MIDI) files. Vision is the only sequencer that lets you save MIDI and audio tracks as a QuickTime movie. But there's more. Vision 3.5 also reads and writes all major audio file types including WAV, au, AIFF, and Sound Designer II. You can also use it like a batch processor to compress and export multiple audio events--what a time saver!
Sound Manager Audio Enhancments
Vision 3.5 uses Sound Manager and Opcode's new SmartSync technology to achieve tighter track synchronization, while doubling the number of audio tracks. Now the fastest Power Macs can support up to 20 tracks of audio--without any additional hardware! Use the new Vertical Zoom buttons to see more of your tracks.Add a Digidesign Audiomedia card to Vision for high quality Analog and Digital I/O. Wow!
Power Mac Native DSP Additions
You'll notice the change right away. New Power Mac native code makes screen redraws and DSP functions up to 20 times faster. That's right, 20 times faster. That'll come in handy when you're using one of the effects from the new DSP menu: Normalize, Reverse, Invert Phase, Convert Sample Rate, EQ or Fade In/Out. Or when you're using one of the popular Adobe Premiere-style plugs, such as Arboretum's Hyperprism or Waves' AudioTrack (get both of these in the Deluxe CD Edition and save a bundle)!
Deluxe CD Edition
All the features we've packed into Vision 3.5 make it a "must have" upgrade, but we wanted to give you more, so we've gone one better. Order the Vision 3.5 Deluxe CD Edition to get all the features mentioned here, plus professional audio capabilities, Galaxy 2.1 and tons of other goodies. Get your music really groovin' for only a few bucks more!
System Requirements for Vision 3.5
MIDI Sequencing:
MAC 68030 or higher, MacOS 7 or higher
8 MB RAM, Large Hard Disk
Recommended for Audio:
16 bit Power Macintosh and above, Level II Cache, MacOS 7 or higher, 12 MB RAM partition for application, large hard disk (2 gig, 7200 RPM preferable), defragmentation utility, CD ROM Drive, Speed Doubler.
Audiomedia II/III use Digidesign DA
