Author Topic: running notator on a pc using STEEM engine emulator  (Read 17266 times)
Re: running notator on a pc using STEEM engine emulator
« Reply #1 on: August 05, 2017, 04:21:34 PM »
i really gotta try this out
notator/creator ! on PC!
can it be used to create tracks in 2017???
Mixermap
« Reply #2 on: August 07, 2017, 04:50:10 AM »
I tried several different "cracks" (originals cannot be used because PCs don't have "dongle" ports :) extensively in steem with several configurations.
It does work and it will recognise a USB MIDI interface (you need to set it up in Steem options).
I tested it with a simple Alesis Control Hub (no drivers required), MIDI keyboard in and out to a Yamaha MU50 sound module.
All the versions I tested worked for about 20 minutes, then they gave an error message (within Creator/Notator) with a box that says "Something unexpected happened. Please do not do it again!" :D
Not sure if it's a problem with Steem or with the cracks themselves. Will test the disks on a real Atari & post results...
« Reply #3 on: August 07, 2017, 05:38:56 PM »
great work !!!!!
so it times out after 20 min or so? strange
wonder if the problem is in the crack.. or the emulator
Mixermap
« Reply #4 on: August 08, 2017, 12:01:37 PM »
It may be the emulator. I tried the Cubase 2 MCA crack (which is legendary here in Europe for being even more reliable than the original!) and in Steem it seems to have problems with hanging notes.
I am going to test the various Notator versions on my real STE in the next couple of days and post back.
« Reply #5 on: August 08, 2017, 12:39:46 PM »
ok just be sure to tell full hardwae spec (ie: what midi interface used with steeem etc)
Mixermap
« Reply #6 on: August 09, 2017, 04:31:26 AM »
Will do :)
