Author Topic: RME DIGI96/8 series :original, PST, PAD, PRO (introduced Oct 1998)  (Read 32079 times)
http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=444.0;attach=9003
RME Digi96.rar contains drivers for win9x,XP &  OS9, OSX Panther
https://archiv.rme-audio.de/en/downloads/driver_updates_readme_digi96.php
October 1998: RME introduces and ships the DIGI96 series, the world's first 24-Bit/96kHz capable digital audio card series.
http://www.rme-audio.de/news/en_list_of_records.php
http://web.archive.org/web/20001203154900/http://www.rme-audio.com/english/index.htm
PAD  /  english https://www.rme-audio.de/download/968pae.pdf
asio driver can handle up to FOUR cards - under which os? probably win98SE?
windows 98/se/me 2000/XP + mac os 8.6 > 9.22
Stereo Analog i/o + SPDif i/o + ADAT i/o = 12 inputs/outputs
PAD: http://www.rme-audio.de/download/968pae.pdf
http://www.soundonsound.com/sos/feb02/articles/rmedigi0202.asp
PST: http://www.rme-audio.de/download/968pse.pdf
http://www.rme-audio.de/old/english/digi96/digi96ps.htm
Features 2 channels digital SPDIF in/out, 8 channel digital ADAT in/out, 2 channel Analog in/out
total inputs: 12
total outputs: 12
rme download center (2006)
http://web.archive.org/web/20060622002639/http://www.rme-audio.com/english/download/index.htm
« Last Edit: November 05, 2023, 08:34:24 PM by chrisNova777 »
Re: RME DIGI96/8 series :original, PST, PAD, PRO (introduced Oct 1998)
« Reply #1 on: January 12, 2020, 07:51:38 AM »
does anyone know if this cards driver will work under osx Tiger?
from what i can see it most likely was last officially supported under Panther
digging deeper into the driver file i find:
This driver was tested under Jaguar 10.2.8 and Panther only. Older versions of OS X are not and will not be supported.
if anyone has any info about it working or not working under osx tiger 10.4 that would be helpful info
« Reply #2 on: July 06, 2020, 06:20:29 AM »
here is the macosx Driver (10.2.8+)
found from here:
http://web.archive.org/web/20060623191149/http://www.rme-audio.com/english/download/drivers.htm
apparently the driver is not INTEL compatible;
but there is a chance it may work on OSX TIGER on a PPC G4
(many PST cards are not electrically compatible with the G5)
does anyone know if the RME 96/8 PST works on windows 7?
« Reply #3 on: July 07, 2020, 04:57:59 PM »
does anyone know if the RME 96/8 PST works on windows 7?  8)
apparently it is rumoured to work fine under windows 7 32bit with the XP driver
but not under 64bit
I think it will work on any 32bit version of windows, windows 10-32bit probably works with the same 2.11 driver
« Last Edit: November 05, 2023, 08:36:39 PM by chrisNova777 »
« Reply #4 on: January 19, 2023, 01:33:55 AM »
i can confirm that the DIGI 96/8 PST does indeed work under OSX TIGER 10.4.11 on a powermac G4 using the posted OSX driver.. it is a bit confusing though.. using DIGI96 settings app is required
i've just tested it on a 1.25Ghz MDD with 750MB of RAM + a USB 2.0 NEC card, Radeon 9000 Pro Graphics
« Last Edit: January 19, 2023, 02:05:31 AM by chrisNova777 »
RME AEB8-I & AEB8-O, AEB4-0 (Analog Expansion Boards)
« Reply #5 on: August 09, 2024, 10:27:19 AM »
RME AEB8-0 (output) & RME AEB8-I (input) 4xSTEREO TRS Analog Expansion Boards
https://archiv.rme-audio.de/old/english/aeb/aeb48o.htm
https://archiv.rme-audio.de/old/english/aeb/aeb48i.htm
therse also AEB4-0 + AEB4-I boards apparently. the "4" boards are mono and the "8" boards are stereo.
The AEB8-O (Analog Expansion Board) adds four analog outputs in professional quality to all ADAT capable RME cards.
The AEB8-O offers 8 outputs with 4 stereo TRS jacks. Usual insert cable can be used to split the connectors from stereo jack to mono jacks. It is also possible to drive up to 4 stereo headphones directly. Level adjustment +4 dBu/-10 dBV, 106 dBA SNR and highest suppression of PC-noise guarantee perfect sound quality.
COMPATIBILITY NOTES
Top
HDSP 9652
Two AEBx-I and two AEBx-O or two TEB can be connected and operated simultaneously, in all possible combinations. One TEB can be used together with either one AEBx-I or AEBx-O.
DIGI96 SERIES
AEBs use the internal ADAT interface of the DIGI cards. Therefore they do not work with the DIGI96 (which did not support ADAT.) To operate the AEB4-I and AEB8-I the used DIGIs must have the connectors ST6/7 on board (for the Word Clock Module.) These were not present on the very first cards of the DIGI96 series (1998 to beginning of 1999.)
One AEBx-I and one AEBx-O can be connected and operated simultaneously, in all possible combinations. Or one TEB.
HAMMERFALL DSP MULTIFACE / DIGIFACE
Multiface and Digiface use the Hammerfall DSP PCI card. This card has no internal inputs or outputs. Therefore no Expansion Boards can be used.
HAMMERFALL SERIES
An operation with the Hammerfall or Hammerfall Light requires board revision 1.5 or higher, because the internal connectors ADAT1Out, ADAT2Out and ST7 were not implemented in earlier versions.
One AEBx-I and two AEBx-O can be connected and operated simultaneously, in all possible combinations. Or one TEB and one AEBx-O.
macos9 driver for RME DIGI96/8 series PCI cards (introduced Oct 1998)
« Reply #6 on: August 09, 2024, 06:36:55 PM »
« Reply #7 on: August 24, 2024, 06:13:40 AM »
i can confirm that the osx driver posted above also works for leopard 10.5.8 on powerpc platform!
