Author Topic: Macintosh IIci (1989) the fastest mac in 1989! 25Mhz!  (Read 22450 times)
« on: September 01, 2017, 08:18:44 AM »
https://en.wikipedia.org/wiki/Macintosh_IIci
http://www.everymac.com/systems/apple/mac_ii/specs/mac_iici.html
http://www.shobaffum.com/iici/
http://www.shobaffum.com/iici/faq.html
The IIci had the best SCSI throughput of any 60830-based Mac, hitting approximately 2.1 MBps, compared with 1.4 MBps for earlier models. Even the “wicked fast” 40 MHz IIfx introduced in 1990 had slower SCSI.
« Last Edit: January 30, 2019, 09:19:03 PM by chrisNova777 »
Re: Macintosh IIci (1989)
« Reply #1 on: September 03, 2017, 11:32:20 PM »
« Last Edit: November 30, 2018, 07:37:40 AM by chrisNova777 »
« Reply #2 on: December 28, 2018, 12:17:40 AM »
 8)
Re: Macintosh IIci (1989) the fastest mac in 1989! 25Mhz!
« Reply #5 on: February 16, 2019, 05:52:11 AM »
https://68kmla.org/forums/index.php?/topic/23703-macintosh-iici-using-vga-adapter/
QuicksilverMac2001
QuicksilverMac2001
6502
Report post
Posted October 14, 2014
I have a Macintosh IIci that I needed a monitor for and I found the Samsung SyncMaster 731N works because it supports all the different methods of sync (H/V sync, composite sync, & sync on green even) as the ancient Apple CRT it was designed to go with, and it supports 640x480 at 67Hz, so with the Enhance Liberty VGA to Mac Adapter (didn't want to play a guessing game of "will this cheaper adapter work" with a Macintosh IIci that I needed running ASAP for the minimum amount of money spent), and I would hope that since the monitor I recommended is so compatible that you may not need an adapter as fancy as the one I am using, I just didn't want any risk of hassle so I bought the over endowed adapter just in case the Samsung monitor died and I had to use something less compassionate.
It seems weird to see a Macintosh IIci drive a flat screen LCD monitor on built-in video, but it's so satisfying at the same time.
« Last Edit: February 16, 2019, 05:52:26 AM by chrisNova777 »
« Reply #6 on: August 18, 2019, 04:27:29 AM »
