Author Topic: Asus p4g8x (2002) motherboard  (Read 6779 times)
« on: September 03, 2017, 06:39:06 AM »
http://www.cpu-upgrade.com/mb-ASUS/P4G8X.html
http://www.cpu-upgrade.com/CPUs/Intel/Pentium_4/RK80532PE083512.html
can take up to a 3.06 HT northwood p4 cpu
https://hothardware.com/reviews/asus-p4g8x-motherboard
https://hothardware.com/reviews/asus-p4g8x-motherboard?page=2
https://hothardware.com/reviews/asus-p4g8x-motherboard?page=3
https://hothardware.com/reviews/asus-p4g8x-motherboard?page=4
CPU
- Supports Socket 478 for Intel® Pentium 4 (Northwood only) processor
- Supports up 3.06G/533MHz and higher speed
Chipset
Intel® E7205 Chipset
- Supports single processor up to 533MHz
- Supports 144bit wide DDR 2100 memory interface, with the
  memory bandwidth of 4.3GB/s or 3.2 GB/s
- Supports AGP 8x or 4x at 0.8V (AGP 3.0) or 4x at 1.5V
Intel® ICH4 Chipset
- AC'97 Controller Integrated
- 2 full IDE channels, up to ATA100
- Low pin count interface for SIO
- Integrated USB 2.0 controller
Bus Frequency
- Supports 100/133MHz FSB
- Supports 400/533MHz Intel NetBurst micro-architecture bus
Memory
- Supports Dual channel (144-bit wide) DDR 266 memory
  interface. Each channel supports 2 DIMM Sockets
- Supports four 184-pin DDR DIMM sockets up to 4GB.
- Supports non-ECC(x64) or ECC(x72) DIMMs DDR PC2001
  DIMM using 128Mb, 256Mb, 512Mb and 1GB SDRAM.
IDE
- An IDE controller on the ICH4 chipset provides IDE HDD/ CD-ROM with PIO,
  Bus Master and Ultra DMA66/100 operation modes.
- Can connect up to four IDE devices.
- Silicon Image  SATALink controller  - 2 Serial ATA ports at 150 MB/s
  operation mode and 1 Ultra DMA port. (optional)
Audio
- Realtek ALC650 6-channel CODEC
System BIOS
- 4Mb Flash ROM, Award® BIOS, TCAV, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, Multi-language BIOS, ASUS EZ Flash, ASUS MyLogo2, CrashFree BIOS, C.P.R
Expansion Slots
- One 8X/4X AGP (Accelerated Graphics Port) universal slot
- Five PCI v2.2 32-bit master PCI bus slots
On Board Ethernet LAN
BROADCOM Gigabit  - 10/100/1000 Mbps Ethernet Controller
- Supports 10Mb/s , 100Mb/s, 1Gb/s auto-negotiation operation
Internal I/O Connectors
On-Board Peripherals include:
- 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M
  and 2.88Mbytes
- 2 serial ports (COM A + COM B)
- 1 parallel port supports SPP/EPP/ECP mode
- 4 USB 2.0/1.1 ports
- 1 Line-In/Line-Out/Mic-In port
- 2 PS/2 connectors
- 1 LAN RJ45 connector (Optional)
Back Panel I/O
2 PS/2 connectors (keyboard and mouse)
2 9-pin Serial port
1 25-pin SPP/ECP/EPP Parallel port
4 USB 2.0 ports
3 Audio connectors (Line-out, Line-in, Mic-in)
1 10/100/1000 LAN connector
Package Contents
Asus P4G8X
User's manual
UltraDMA cable
IDE cable
FDD cable
2-port USB 2.0 / Game port module
S/PDIF in/out module (optional)
I/O shield
InterVideo WinCinema (Gold version only)
Form Factor
ATX Form Factor 12" x 9.6" (30.5cm x 24.5cm)
« Last Edit: September 03, 2017, 09:26:28 AM by chrisNova777 »
