Author Topic: Akai DD8 Digital Dubber (1996)  (Read 9430 times)
« on: September 06, 2017, 01:04:10 PM »
http://www.mixonline.com/news/profiles/akai-dd8-digital-dubber-tips-todd-ao-east/373940
http://www.futurestyle.org/archives/a/akaiDD8plus.htm
The Akai DD8 random-access digital film dubber is designed to be used in place of traditional mag machines and as a plug-and-play replacement for tape-based recorders and playback machines. It records to and plays from 2.6GB magneto-optical (MO) disks or removable hard drives and now offers 24-bit/96kHz resolution.
Re: Akai DD8 Digital Dubber (1996)
« Reply #1 on: January 30, 2018, 01:54:43 PM »
https://web.archive.org/web/20030108142057/http://www.akaipro.com:80/consumersite/productpage.asp?id=93&section=
DD8 Modular 8-track Magneto/Optical Dubber
The DD8 is a magneto/optical-based, random-access digital film dubber designed as a plug-and-play replacement for the DA-88. It features virtually instant locating, convenient removable media, flexible I/O and remote control options, and data compatibility with the Akai DD1500 Recorder/Editor. And it syncs to everything. Forward and reverse. At any speed.
Check out these features:
A random-access, magneto/optical-based digital recorder specifically designed as a film dubber
Record to and play from 2.6GB MO disks or removable hard disks
Plug-and-Play replacement for the Tascam DA-88
Direct data compatibility with the DD1500 MO Recorder/Editor
Uncompressed 16-bit linear data format
Flexible I/O formats and extensive synchronization options
Extremely high quality scrubbing
Designed for ease-of-use on the dubbing stage
Virtually instantaneous locating to any point -- no waiting for tape winding
Dedicated Track Slip and Event/Region Nudge buttons
Punch-in recording with Track Select keys or via GPIO parallel interface
Operating System in Flash ROM for instant boot-up and easy updates
Pre-read outputs
Undo/Redo
New Features
Direct playback of OMF files from DAW systems such as Digidesign ProTools, Avid AudioVision, and Avid MediaComposer, to name a few
https://web.archive.org/web/20030106170313/http://www.akaipro.com:80/consumersite/productpage.asp?id=94&section=
DD8plus Modular Digital Random Access Dubber
24-bit, 96kHzThe DD8 is a magneto/optical-based, random-access digital film dubber designed as a plug-and-play replacement for the DA-88. It features virtually instant locating, convenient removable media, flexible I/O and remote control options, and data compatibility with the Akai DD1500 Recorder/Editor as well as the main disk/file formats used by DAWs and disk recorders. And it syncs to everything. Forward and reverse. At any speed.
Record to and play from MO disks or removable hard disks
Direct data compatibility with the DD1500 MO Recorder/Editor, as well as Macintosh disks: OMF, ProTools®, AIFF/SD2 audio; DOS disks : Zaxcom DEVA, .WAV/BWF audio; Tascam™/Timeline™ MMR-8, Waveframe™, Fairlight MFX3Plus™DaD.
Uncompressed 16, 20 and 24 bit data formats
Sample Rate up to 96kHz
Pre-read outputs
Undo/Redo
New Features
24-bit, 96kHz recording/playback capability
Direct playback of OMF files from DAW systems such as Digidesign ProTools, Avid AudioVision, and Avid MediaComposer, to name a few.
