Author Topic: Edirol UM-3X (2005)  (Read 8141 times)
Edirol UM-3X (2005)
« on: November 08, 2017, 12:21:28 AM »
https://web.archive.org/web/20050728140240/http://www.edirol.com:80/products/info/um3ex.html
The UM-3EX is the most innovative mid-sized MIDI interface in the market. The expandable design of the UM-3EX makes it the ideal MIDI interface for a relatively small studio, but allows you to daisy-chain up to three UM-3EX’s together for a total of 9 MIDI inputs and outputs. The UM-3EX can be mounted into the RAF-70, a rack-mount kit, making for a clean, expandable studio installation.
The UM-3EX allows you to select between MIDI Out and MIDI Thru for each output port.
The UM-3EX uses FPT (Fast Processing Technology) to ensure low-latency, low-jitter MIDI transmission, even with three devices daisy-chained together.
Main Features
3-In/ 3-Out MIDI ports (female)
OUT or THRU selectable switches built-in
USB Hub built-in and up to 3 units cascade connection
Control up to 48 channels of MIDI equipment
Rack-mountable in a RAF-70
Fast and stable MIDI data transmission realized by FTP
USB Bus Powered and AC Adaptor not required
* Must have a compatible USB host controller.
EDIROL designs its USB devices in accordance with USB specifications and has passed all compatibility tests, which are continuously held and organized by USB Implementers Forum (USB-IF).
