Author Topic: Syba SI-PEX40058 PCI-E x2 fits x4,x8 or x16 slot, gives 500Mb/s-1000Mb/s  (Read 699 times)
SI-PEX40058
**** This card will not fit into a PCI-e 1.0 x1 slot,  PCI-Express x2 Interface is Compatible with PCI-Express x4, x8, and x16 slots
if the above logic is true, im hoping this adapter will provide thruput of 500mb/s in a pci-e v1.0 x16 slot???
www.sybausa.com/index.php?route=product/product&product_id=173
"Each PCI-Express 2.0 lane provides up to 500Mb/s of throughput. "
or "Each PCI-Express 1.0 lane provides up to 250Mb/s of throughput"
Specifications:
    Chipset: Marvell 88SE9230
    Ports:
        2x Internal SATA 6Gb/s Ports
        2x External SATA 6Gb/s Ports
    Compliant with PCI-Express Specification v2.0 and Backward Compatible with PCI-Express 1x
    Compliant with Serial ATA Specification 3.0
    Supports Communication Speeds of 6.0 Gbps, 3.0 Gbps, and 1.5 Gbps
    Hot Plug and Hot Swap
    Supports Native Command Queue (NCQ)
    Supports Port Multiplier FIS Based Switching or Command Based Switching
    Compatible with SATA 6G, 3G and 1.5G Hard Drives
    RAID Function:
        RAID 0-Striping (Stripe Size: 32K, 64K)
        RAID 1-Disk Mirroring
        RAID 10-Stripe of Mirrors (Stripe Size: 32K, 64K)
    HyoperDuo Safe (Mirrored Protection) or Capacity-Cost (Optimized)
    Note: Not Supported RAID on PM
Package Includes:
    SATA III 2 External 2 Internal 4-port PCI-e Version 2, x2 Slot Controller Card
    Driver CD
    19" SATA Cables (x2)
    Low Profile Bracket
    User Manual
Software Requirement:
    Windows 8
    Windows 7
    Vista
    Windows XP
    Server 2008
    Server 2008 R2
    Server 2003
    Linux 2.6.x and Above (AHCI devices driver is a built-in feature)
Hardware requirement:
    Computer Motherboard with PCI-e Version 2.0 x2 Slot (This card will not fit into a PCI-e 1.0 x1 slot)
« Last Edit: November 05, 2018, 09:02:58 AM by chrisNova777 »
