Author Topic: iconnectMIDI1 Lightning version 1in 1out  (Read 4462 times)
« on: December 02, 2018, 10:23:04 PM »
https://www.ebay.com/itm/iConnectMIDI1-Lightning-Version-1-in-1-out-USB-to-MIDI-Interface-for-Mac/173623949960?hash=item286ccb3a88:g:xBUAAOSwfgRb37wH:rk:35:pf:0
https://www.iconnectivity.com/products/midi/iconnectmidi1/
https://www.sweetwater.com/store/detail/iConnMIDI1L--iconnectivity-iconnectmidi1
What Makes iConnectMIDI1 Unique?
Even the most basic tasks need to be done right. So we engineered a new basic MIDI interface from the ground up that does everything right.
Not one of our competitors' 1x1 MIDI interfaces could pass all our tests:
Incompatible drivers - Interfaces that use their own drivers have to be updated all the time, or they stop working properly. Or they were USB Class-Compliant years ago, but today they aren't anymore. Ours is engineered to today's strict guidelines to ensure compatibility for years to come.
Poor MIDI Management - When the MIDI datastream gets heavy, other interfaces choke. Our interfaces deliver MIDI reliably no matter what.
Bad Electrical Design - You don't want a MIDI interface that introduces noise or even crashes your system, like some do. Ours is engineered properly.
Not Performance Optimized - A MIDI interface that works too slowly is useless. Ours is optimized for the highest performance.
The iConnectivity Advantage: iConnectivity’s name on your interface means we took the time to do it right, whether it's our simple 1 x 1 models to our uniquely sophisticated high-end interfaces.
Key features
1 in and 1 out set of MIDI DIN ports
Supports 16 channels of MIDI I/O
iOS compatible
Mac and PC compatible
USB bus powered
USB bus powered
Plug and play - no drivers needed
USB MIDI Class Compliant
MAC and PC compatible
