Author Topic: FIC PA-2013 Motherboard  (Read 6408 times)
Online chrisNova777
« on: December 26, 2018, 05:16:50 AM »
https://www.anandtech.com/show/1
http://www.interloper.com/products/product-details.php?productid=101887&cat=310
   MODEL
FIC PA-2013
MICROPROCESSOR
321-pin ZIF socket (Socket 7) with Switching Voltage Regulator 2.0~3.5V
Intel Pentium ® processor with MMX technology 166-233 MHz
AMD-K6 PR166-PR300 / K6 3D* processors up to 550MHz
Cyrix/IBM 6x86MX PR166-PR233 processors
Supports 66/75/83/100MHz Front Side Bus
CHIPSET
VIA Apollo MVP3 Chipset
CACHE
Onboard 1MB Pipeline Burst Synchronous SRAM Standard
MEMORY
3 x 168-pin DIMMs sockets; EDO/ SDRAM support; Supporting up to 384MB RAM**; ECC memory support
EXPANSION SLOTS
1 x 32-bit AGP slot + 4 x 32-bit PCI slots + 2 x 16-bit ISA
I/O
Winbond 877TF/AF I/O chipset; 2 serial ports with 16550 UART/IrDA;
1 parallel port with EPP/ECP; On Board PS/2 connector; On Board dual channel USB connector
ON BOARD PCI IDE
Two dual-channeled Enhanced PCI Bus Mastering IDE connectors;
Ultra DMA/33 support, PIO Mode 4; DMA Mode 2 support;
BIOS
Plug and Play, DMI 2.0 compliant, Flash EPROM, LS-120 support
SYSTEM PROTECTION & POWER MANAGEMENT
Hardware-Based intelligent virus protection; CPU Thermal Protect, CPU/System Fan Control, Voltage Report (mfg. option); ACPI (Advanced Configuration and Power Interface) ready***; RTC alarm; Modem Ring-On; 5V Standby; Doze/Sleep/Suspend Modes
DIMENSIONS
ATX size; 4-layer; 12" x 8"
