Author Topic: Logic Delta CD (bundled with M-audio Delta PCI sound cards) XP/Win98SE + MacOS9  (Read 11187 times)
https://www.mediafire.com/file/d8c7dlq5d606drc/Logic_Delta_CD.toast/file
http://web.archive.org/web/20010816050524/http://www.m-audio.com/maudiofrontpage/logicdelta/logicdelta.html
Logic Delta features:
    Mac & PC compatibility - (Windows 98, Windows 98SE/Me for USB)
    24bit/96kHz operation
    VST and Direct X support
    Record up to 10 audio tracks simultaneously
    Playback 16 audio tracks
    unlimited MIDI tracks
file is a 27MB .toast file, you can burn it, mount it, or rename to .iso
Offline foksadure
  • Stuck in 1997
Authentic ISO9660 rip of the Mac/PC Logic Delta CDR (258MB), straight from the attic. :D
Offline 6track
  • Jr. Member
Logic Delta 4.6.2 Portable
« Reply #2 on: July 29, 2022, 02:45:44 AM »
Thanks!
Logic Delta 4.6.2 Portable - 10,2 mb
Windows XP-10
- Removed manual and demo song for minimum size.
! PlugIn Enabler does not work on Windows x64 (ASIO drivers will not work for the same reason). Logic Delta 4.6.2 requires Windows 95/98.
Offline foksadure
  • Stuck in 1997
Re: Logic Delta 4.6.2 Portable
« Reply #3 on: July 29, 2022, 04:25:02 PM »
Cool.
IDK about your way of packaging the app to make it portable, but FWIW, the regular installer found on the CDR works on Win10x64 when using Windows 95/98 Compatibility mode.
And the app is working ok afterwards, even in ASIO mode for audio, which is pretty neat.
You need a real Delta series card in the computer of course.:P
« Last Edit: July 29, 2022, 04:49:58 PM by foksadure »
Offline 6track
  • Jr. Member
« Reply #4 on: July 30, 2022, 12:54:09 AM »
I realized I need an M-Audio card.
Portable options are convenient in that they do not depend on the computer - you can use your own, work or a friend. No trace. You have all your favorite collection of DAWs, editors and DX\VST without having to install and register it. And all this on a small flash drive.
I made about 200-300 portable builds. Here is one of the collections on this Windows 7x64 machine. There are almost 100 builds here: Reaper, FL studio, Orion, SoundForge and more, including about 700 DX/VST and portable NET Frameworks with all versions of Visual C++ portable. There is no conflict with the other software that was installed on the computer. Portable builds run in the ThinApp virtual environment, only in their own sandbox.
Offline foksadure
  • Stuck in 1997
Yeah, found out about your file being a VMWare ThinApp packaged app when looking at the Sandbox content.
Too bad it does not work with 16bit apps. :P
Yet, Logic Delta is not quite the best candidate for app virtualization IMHO, since it's Win95 up to Win10x64 compatible already.
As I wrote in the other thread, it has very few dependencies and can be run on from any folder as long as the EASI MME.hlp, EASIDS.dll and log_ds.ax files are in the host Windows/system folder.
About the overhead from using virtualization, there's a slight 12.5% loss on the accuracy of the physical MIDI Out clock between the virtualized app versus the installed one, on the same computer with the same*.lso project and Audio/MIDI settings. That's 4.5% vs 4% jitter on the Delta MIDI Out DIN (no USB involved), which is acceptable for a Win10x64 system anyway. Older 9x Windows always win on this.
« Last Edit: July 30, 2022, 09:59:00 AM by foksadure »
Offline 6track
  • Jr. Member
16-bit applications can be ThinApp'd on 32 bit OS but 16-bit applications cannot be executed on 64-bit platforms due to OS limitation.
Offline 6track
  • Jr. Member
Logic Audio Platinum 5.3.0 + 5.5.1 + Logic Delta 4.6.2 Portable
« Reply #7 on: July 30, 2022, 09:27:20 AM »
Logic Audio Platinum 5.3.0 + 5.5.1  + Logic Delta 4.6.2 Portable - 33 mb
Windows XP-10
! Logic Delta 4.6.2 requires Delta Card.
!! If 5.5.1 does not run on Windows x64, run 5.3.0 first. Close and then run 5.5.1.
Offline ehma
First of all, thanks to Foksadur for his help on another forum.
Just for information
I actually have 2 m-audio sound cards and both originally had Logic Delta built in.
This Windows version of Logic Delta only works with the Delta series unlike the newer version 4.8.1 uploaded by Chrisnova, which also works with the Quattro series.
