Author Topic: I'm looking for a Rebirth download that would work on windows 10  (Read 5328 times)
Offline luce
  • old school music enthusiast
    • my soundcloud
Heyo, I'm currently trying to find a version of Rebirth that works with x64bit Windows 10.
I've tried three different installs and they all launch, but crash after a second.
I already have an iso file of the disc, so that's not my issue, I just need an installer that'll work properly on windows 10 64 bit.
Re: I'm looking for a Rebirth download that would work on windows 10
« Reply #1 on: March 09, 2019, 06:42:53 PM »
it only works on 32bit operating systems
i have it working on windows 7-32bit
i think windows 10 can be installed with 32bit in which case it would work.
maybe run it on anothjer computer + network via midi/audio?
you can try this :
https://francisfisher.me.uk/problem/2015/how-to-use-reason-with-rebirth-rb-338-on-64-bit-windows-7-or-8/
ahh ok so according to this u can force reason to run in 32bit mode,
instead of reinstalling your os... and then it will work.
you will have to use some type of compatibility for 32bit programs to get the installer to work?
i havent tried it.. check the blog post
Offline 6track
  • Jr. Member
ReBirth RB-338 2.0.1 works successfully on Windows 10 x64 with Reason 1.
« Reply #2 on: January 09, 2025, 02:12:11 PM »
1. Copy file rb20crk.dat to C:\rb20crk.dat (NoCD)
2. Copy folder ReBirth RB-338 to C:\Program Files (x86)\Propellerhead\ReBirth RB-338\ (program folder)
3. Copy file ReBirth RB-338 2.prf to C:\Windows\ReBirth RB-338 2.prf (empty settings file that will help you open the program for the first time)
4. Run file ReBirth RB-338.reg (for ReWire)
Code: [Select]
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Propellerhead Software\ReWire\ReBirth RB-338]
"Device Path"="C:\\Program Files (x86)\\Propellerhead\\ReBirth RB-338\\ReBirth.dll"
5. Copy files ReWire.dll and REX Shared Library.dll to:
C:\Windows\ReWire.dll
C:\Windows\REX Shared Library.dll
C:\Windows\SysWOW64\ReWire.dll
C:\Windows\SysWOW64\REX Shared Library.dll
Important:
1. If the program folder is copied to another location, edit ReBirth RB-338.reg (for ReWire).
2. NoCD rb20crk.dat must be in the root of the disk where the program folder is located.
« Reply #3 on: January 16, 2025, 10:15:08 PM »
thank you Juno6!   8) aka 6track
Offline 6track
  • Jr. Member
Portable Reaper 7.30 x64 successfully works with ReBirth RB-338 2.0.1 and Reason 1.0.1 on Windows 10 x64 via ReWire too.
! ReWire setting is disabled in portable Reaper by default. You need to open the reaper-install.ini file in the Reaper folder and enable ReWire (set rewire=1).
Code: [Select]
[REAPERinst]
reamote=1
rearoute=0
rewire=1
desktop=0
startmenu=0
assoc=0
jsdata=1
Also don't forget about the presence of ReWire.dll in C:\Windows\ReWire.dll and C:\Windows\SysWOW64\ReWire.dll (see the message above about ReWire).
ioreg
« Reply #5 on: February 21, 2025, 03:57:37 PM »
Doesn't v6 work with reason?
Offline theboomrefk
« Reply #6 on: April 29, 2025, 04:30:03 PM »
If you thinking about v2.0.1, well... it's the last release of Rebirth, before it became discontinued
Here's an excerpt from a SOS article from 2005 to prove it:
"Development of Rebirth effectively ceased with v2.0.1, and although some users might like to see the classic software rebuilt for modern times (especially for Mac OS X), Propellerhead have decided that their resources are better deployed on current and future projects." - https://www.soundonsound.com/techniques/rebirth-reason
Offline DEVICEHIGH
« Reply #7 on: May 01, 2025, 12:30:54 AM »
https://audiovst.mnx2010.nl/rebirthreason.htm
This page has everything needed for running Rebirth on Windows 7/8 and 10/11, x86 and x64.
I tested it on Windows 7 x64.
« Reply #8 on: May 11, 2025, 04:34:14 PM »
its not that its so special - it just has all the things you need to use the roland soundsets from the roland instruments featured in rebirth. thereby allowing people to use the sounds without owning teh equipment which is expensive. theres many other ways around this obviously now adays but when rebirth came out it was a huge deal i remember using it in our high school parking lot on a car with a crazy soundsystem and the rush i got from seeing peoples reaction to what i was making was enough to solidify rebirth as legendary. i was using an old pentium II laptop i think. back in like 1998 or 1999.
