Author Topic: Sample Vision DOS (May 1993) for use with TRUE Mpu-401 or SoundBlaster MIDI port  (Read 31034 times)
Online chrisNova777
http://vetusware.com/download/Sample%20Vision%202.01/?id=9053
http://www.muzines.co.uk/articles/turtle-beach-softworks-sample-vision/2203
see this thread: http://www.oldschooldaw.com/forums/index.php?topic=2387.0
   Sample Vision is a DOS utility that manipulates sound samples stored in MIDI controlled samplers from the early 1990s for example Ensoniq EPS, Kurzweil K2000, etc. It is designed to use a MPU-401 compatible interface, however there is a work around that allows use of the standard sound blaster midi port by accessing the MIDIPORT utility on the first disk and typing "MIDIPORT MPU 1 1 5 20 20 330" before running Sample Vision.
« Last Edit: January 28, 2018, 05:36:10 PM by chrisNova777 »
Reverend Recode
WHOA!! I missed the FFT browser first time. I will most likely get this going again in a VM. Do a few youtubes.
Online chrisNova777
in a VM? no point. unless hardware integration works somehow in a VM?
Offline pixelwings
Unfortunately, I cannot get this to work with my Creative Vibra 16 / SB16 card at all. Card works fine and all, drivers installed both in DOS and win3.1. The Sample Vision program also launches and generally works, but will always get a interface error upon startup. No matter my settings.
