Author Topic: Whats an Insert Cable?  (Read 1414 times)
« on: December 24, 2019, 09:35:12 AM »
https://www.sweetwater.com/insync/insert-cable/
A cable that splits a TRS plug to two TS plugs, with separate signals carried on the two split plugs. This differs from a “Y” cable, where the same signal is carried on the two split plugs. Insert cables are often used to access the send/return on a mixer insert,
but have other uses as well, such as splitting a stereo output carried on a single Stereo TRS jack to separate left/right signals on TS plugs.
« Last Edit: December 24, 2019, 09:36:22 AM by chrisNova777 »
