Author Topic: Tascam US-428 (2001) DAW controller for win98se/me/2k/xp, macos8/9  (Read 14700 times)
https://web.archive.org/web/20061109133414/http://www.tascam.com/Products/US-428.html
https://www.emusician.com/gear/tascam-us-428-digital-audio-workstation
http://web.archive.org/web/20031208115723/http://www.tascam.com:80/product_info.php?pid=270&nav=computer_recording
http://www.emusician.com/gear/1332/tascam-us-428-digital-audio-workstation/32254
http://www.zzounds.com/item--TASUS428
Minimum System Requirements
US-428
MAC: PPC; 64 MB RAM (128 MB recommended); OS 8.6.1 or later (no OS X support); USB port
PC: Pentium/200 (Pentium II/300 recommended); 64 MB RAM (128 MB recommended); Windows 98 SE/ME/2000; USB port
US-428 Specifications
Analog Inputs(2) balanced XLR mic-level; (2) balanced ¼" line-level (+4 dBu); (2) unbalanced ¼" switchable between line-level and high impedance (-10 dBV)Analog Outputs(2) unbalanced RCA (-10 dBV); (1) ¼" stereo headphoneDigital I/O(1) S/PDIF coaxial RCA stereo in; (1) S/PDIF coaxial RCA stereo outResolution16-bit; 24-bitSampling Rates44.1, 48 kHzFrequency Response20 Hz-20 kHz (+0.5, -0.3 dB)Total Harmonic Distortion<0.07% @ 1 kHz (mic A/B to line out)Noise LevelBetter than -88 dBu A weightedMIDI I/O(2) In; (2) OutDimensions11.5" (W) × 14" (H) × 3.25" (D)Weight4.5 lbs.
A complete computer recording solution with Cubase LE 48-track recording software and GigaStudio 3 LE!
TASCAM and Frontier Design Group have partnered together to create the first major innovation in USB-based audio. Start with a fully 24-bit front end, with two XLR inputs, two balanced 1/4" TRS inputs, two unbalanced 1/4" inputs (switchable to Hi-Z), and S/PDIF I/O. Four channels of audio in and two out simultaneously via USB. No opening your computer, no sound card to install - it's USB, so you can even hot-plug it.
You'll spend a lot less time mousing your mix with the US-428. It's got real tactile controls for the most-used functions in your DAW applications. Transport, mute/solo and locate keys, unlimited banks of eight faders, an EQ module that supports control of up to four bands of fully parametric EQ, plus four aux sends and a panpot. It's even got 32 channels of MIDI I/O. Use one for your keys and modules, and the other for MTC, to lock your MTC-capable tape tracks to your computer.
The US-428 comes bundled with a custom version of Steinberg's Cubasis VST audio recording/MIDI sequencing software. The PC version is available with US-428s shipping now, while the Mac version will be available soon and will be shipped to previous purchasers of the US-428 free of charge.
PC or Mac Compatible via USB interface
24 bit D/A and A/D converters
Four in (analog or S/PDIF) and two out simultaneously
Records at up to 48kHz, 24-bit resolution
Two independent MIDI I/O
Supports unlimited banks of eight faders
Dedicated EQ, Aux and Pan controllers
Includes Cubase LE 48-track / 96kHz recording software
Includes GigaStudio 3 LE 64-voice sampling software
http://tascam.com/content/downloads/products/316/US-428_manual_V3.pdf
http://web.archive.org/web/20011205095352/http://www.tascam.com/products/us428/downloads.php
http://www.soundonsound.com/sos/may01/articles/tascamus428.asp
power supply replacement information:
Version Voltage Hz Power Consumption
DM 100 50/60 7.5 (50Hz)
T/C 120 60 7.5 (60Hz)
EUR 230 50 7.5 (50Hz)
UK 240 50 7.5 (50Hz)
AUS 240 50 7.5 (50Hz)
AC Adaptor PS-P428 (7.5 VAC, 1000 mA)
click here
Product Description
Tascam and Frontier Design Group have partnered together to create the first major innovation in USB-based audio. Start with a fully 24-bit front end, with 2 XLR inputs, 2 balanced 1/4 in. TRS inputs, 2 unbalanced 1/4 in. inputs (switchable to Hi-Z), and S/PDIF I/O. Four channels of audio in and 2 out simultaneously via USB. No opening your computer, no sound card to install — it's USB, so you can even hot-plug it.
You'll spend a lot less time mousing your mix with the US-428. It's got real tactile controls for the most-used functions in your DAW applications. Transport, mute/solo, and locate keys, unlimited banks of 8 faders, an EQ module that supports control of up to 4 bands of fully parametric EQ, plus 4 aux sends and a panpot. It's even got 32 channels of MIDI I/O. Use one for your keys and modules and the other for MTC to lock your MTC-capable tape tracks to your computer.
The US-428 comes bundled with Steinberg's Cubasis VST audio recording/MIDI sequencing software.
Features
PC or Mac compatible via USB interface
24-bit D/A and A/D converters
4 in (analog or S/PDIF) and 2 out simultaneously
2 independent MIDI I/O
Supports unlimited banks of 8 faders
Dedicated EQ, Aux, and Pan controllers
Technical Description
Frequency Response: 20 Hz - 20 kHz/0.5 dB/-0.3 dB
LINE A/B to LINE OUT
LINE TRIM max, -28dBu input
LINE OUT Level -10dB position
Noise Level: Better than -82dBu Din Audio; Better than -88dBu A Weight
MIC A/B to LINE OUT
LINE TRIM min, 150 ohm terminated
Signal Processing Delay: Less than 2 ms
MIC/LINE to LINE OUT Cue Monitor
Fs = 44.1KHz
THD: Within 0.07%
MIC A/B to LINE OUT
Crosstalk: Better than -80 dB at 1KHz
Click: Less than -35 dBu
Fader Attenuation: Better than -90 dB at 1 KHz
Mute Level: Better than -90 dB at 1 KHz
Dimensions: 14 x 11.5 x 3.25 in. (35.5 x 29.5 x 8 cm)
Weight: 2.05 kg (4.5 lbs.)
Power Consumption: Version, Voltage, Hz, Power Consumption
DM, 100, 50/60,7.5 (50Hz)
T/C, 120, 60, 7.5 (60Hz)
EUR, 230, 50, 7.5 (50Hz)
UK, 240, 50, 7.5 (50Hz)
AUS, 240, 50, 7.5 (50Hz)
MIC INPUT A/B (Analog)
Connector: XLR-3-31
(1:= GND, 2:= Hot, 3:= Cold): Balanced
Input Impedance: 2200 ohm
Nominal Input Level (Trim max.): -63 dBu
Nominal Input Level (TRIM min.): -16 dBu
Maximum Input Level: 0 dBu (TRIM min)
LINE INPUT A/B (Analog)
Connector: 1/4" TRS
(Tip: Hot; Ring: Cold, Sleeve: GND)
Input Impedance: 22kOhm
Nominal Input Level (TRIM max.) -43 dBu
Nominal Input Level (TRIM min.): +4 dBu
Maximum Input level: +20 dBu (TRIM min)
LINE INPUT C/D (Analog)
Connector: 1/4"
(Tip: Hot; Ring: GND; Sleeve: GND) Unbalanced
Input Impedance 47Kohm at MIC/LINE; 680Kohm at GUITAR
Nominal Input Level (TRIM max.): -46 dBu
Nominal Input Level(TRIM min.): -10 dBV (-7.8 dBu)
Maximum Input Level: +6 dBV (+8.2 dBu) (TRIM min)
LINE OUTPUT (Analog)
Connector: RCA pin jack, Unbalanced
Output Impedance: 100ohm
Nominal Output Level: -10 dBV (-7.8 dBu)
(LINE LEVEL -10dB)
Maximum Output Level: +16 dBV (+18.2 dBu)
(LINE LEVEL max)
PHONES OUTPUT (Analog)
Connector: 1/4" TRS Stereo
(Tip: L, Ring: R, Sleeve: GND)
(when nominal impedance 40 Ohms loaded)
DIGITAL IN
Format: IEC958 TYPE2
Input impedance: 75ohm
Input Level: 0.5Vp-p
DIGITAL OUT
Format: IEC958 Type 2
Output Impedance: 75 ohm
Output Level: 0.5Vp-p
MIDI IN 1,2
Connector: 5P DIN
Format: Standard MIDI Format
MIDI Out 1,2
Connector: 5P DIN
USB
Connector: USB Down stream connector
Format: USB
ADC/DAC
A/D Converter
24-bit, 64 times oversampling
Delay: 30 samples
D/A Converter
24-bit, 128 times oversampling
Delay: 30 samples
Audio Performance
MIC Input (A,B XLR Analog Input to Digital Output)
Nominal Level (TRIM max.)
-65.2dBu +1dB/-1dB
TRIM max, 1KHz, (-48dBu input)
Nominal Level (TRIM min.)
-16.2dBu +0.5dB/-0.5dB
TRIM min, 1KHz, (9dBu input)
Frequency Response: 20 Hz - 20KHz + 0.2dB/- 3dB
TRIM max, -48dBu input
20 Hz - 20KHz + 0.1dB/-2dB
TRIM min, 0dBu input
Noise Level
Within -81dBFs Din Audio
Within -83dBFs A Weight
TRIM max, 150 ohm terminated
Within -95dBFs Din Audio
Within -98dBFs A Weight
TRIM min, 150 ohm
T.H.D.: Typical 0.04% at 1KHz
TRIM max, -48dBu: Better than 0.005% Typical 0.003% at 1KHz
TRIM min, 0dBu
LINE Input (A,B 1/4" Analog Input to Digital Output)
-45.7dBu, +1dB/-1dB
TRIM max, 1KHz, (-28dBu input)
-16.2dBu, +0.5dB/-0.5dB
Frequency Response
20 Hz - 20KHz, + 0.2dB/- 3dB
20 Hz - 20KHz, + 0.1dB/-2dB
LINE Input (C,D Analog Input to Digital Output)
-46.6dBu, +1.5dB/-1.5dB
TRIM max, 1KHz, (-30dBu input)
7.09dBu, +0.3dB/-0.3dB
Frequency Response
20 Hz - 20KHz, + 0 .5dB/- 2dB
TRIM max, -30dBu input
20 Hz - 20KHz, + 0.3dB/-0.3dB
TRIM min, 9dBu input
Noise Level
Within -82dBFs Din Audio
Within -95dBFs Typical -97dB Din Audio
Within -98dBFs Typical -99dB A Weight
T.H.D
Better than 0.03% Typical 0.01% at 1KHz
TRIM max,-30dBu :
Better than 0.04% Typical 0.03% at 1KHz
TRIM min, 8dBu
LINE OUT (Digital Input to LINE OUT)
Nominal Output: 6dBV, +1.2dB/-1dB
D IN 0dBFs input, LINE OUT Level -10dB position
Frequency Response:
20 Hz - 20KHz, + 0.2 dB/-0.4 dB
T.H.D.: Better than 0.003% Typical 0.0025% at 1KHz
Noise Level:
Within -95dBV Din Audio
Within -99dBV A Weight
PHONES Output
Maximum Output: More then 28mW + 28mW Typical 32mW + 32mW
Within 1% distortion, at 1KHz, 40 ohm loaded
T.H.D.: Within 1 %
1KHz, Output 25mW + 25mW, 40 ohm loaded
Frequency Response:
100 Hz - 20KHz, + 0.5dB/- 0.5 dB
Nominal level, 40 ohm loaded
20 Hz - 100 Hz, +0.5dB/- 5dB
Re: Tascam US-428 (2001) DAW controller for win98se/me/2k/xp, macos8/9
« Reply #1 on: April 14, 2018, 09:16:43 PM »
« Reply #2 on: October 13, 2020, 01:58:48 AM »
