Author Topic: 19" Saffire Pro 40 (2009) 20 Inputs and 20 Outputs  (Read 6899 times)
« on: January 20, 2020, 09:34:47 AM »
http://web.archive.org/web/20081227152101/https://focusrite.com/products/saffire/saffire_pro_40/
https://www.soundonsound.com/reviews/focusrite-saffire-pro-40
https://www.musicradar.com/reviews/tech/focusrite-saffire-pro-40-198935
originally Supported OSX Leopard 10.5.x (which was the current osx when it was released)
originally supported Windows XP SP2
"Compatible with: Mac OS 10.4 and above, Windows XP SP2 and Vista."
Eight High Quality Award-winning Focusrite Pre-amps
The best sounding interface in its class. Focusrite's unparalleled pre-amp legacy forms the foundation of this new interface, with eight award-winning Focusrite pre-amps.
High Quality 24-bit/96kHz Firewire Interface
Features high quality A-D / D-A conversion and JetPLL™ jitter elimination technology; pristine audio quality and reliable synchronisation are guaranteed.
Total I/O Count of 20 Inputs and 20 Outputs
A host of i/o options are provided*, including a unique loop-back facility for routing audio between software applications via Saffire PRO 40 Control.
The Focusrite Plug-in Suite
Upgrade your standard sequencer effects and bring a touch of class to your session with all-new Focusrite Compression, Reverb, Gating and EQ VST/AU plug-ins.
Two separate headphone buses
Two artists can receive independent and fully customised monitor mixes. Each output has an independent level control available on the front panel.
Saffire PRO 40 Control Zero-latency DSP Mixer/Router
Routing flexibility and intuitive one-click set-up solutions; Saffire PRO 40 Control provides an 18 x 16 DSP mixer with excellent output routing and monitoring capabilities.
Unmatched routing flexibility
Saffire PRO 40 is the most flexible interface in its class, able to adapt to any recording session quickly and intuitively. The user is able to route any input signal or DAW output, or a mix of both, to any of the 20 outputs.
