Author Topic: MED soundstudio (OctaMED) for windows TRIAL  (Read 13519 times)
« on: February 25, 2021, 05:55:14 PM »
http://web.archive.org/web/20080730010741/http://www.medsoundstudio.co.uk/pc_frames.htm
http://web.archive.org/web/20080730010735/http://www.medsoundstudio.co.uk/
Welcome!
-Remember the free Amigatracker called MED and from 1991 the famous award winning commercial version OctaMED?
-With the death of the Amiga OctaMED was re-coded/renamed as MED Soundstudio for use on the PC (Windows XP/Vista/Windows 7 & 8).
-MED Soundstudio is a Stereo Tracker/MIDI Sequencer for sound editing, a massive number of Real time Effects, with full VSTi and also offering ASIO support.
-Other than a quality soundcard, MED requires no other additional hardware,(although it can be used to control MIDI/sequencing)
-Once you become familar with the myriad of features within MED you will be suprised to learn how flexible the program is.
-You can select to save your compositions out as either an MMD file for loading into MED itself or a MIDI file and for those contacts who do not use MED, they can simply play back your MED MMD file via one of the many music players, such as WinAmp, or you can choose to save your music as a standalone self-executing file which only requires the user to click on the saved executable file to hear your work.
-With a CD burner you can save your files in the .WAV format ready to burn directly to a CD, or using the plugin addition, you can select to save in the popular MP3 encoded format.
-For reliable use, an Intel Pentium 4/Celeron family, AMD K6/Athlon/Duron family, (or compatible dual core processor), with 800-MHz (or better), 128MB RAM, (or higher), (runs on Vista-but who would want to!).
Windows XP/7/8 are highly recommended.
http://web.archive.org/web/20150825235631/http://www.medsoundstudio.webspace.virginmedia.com/index1.htm
http://web.archive.org/web/20150608214211/http://www.medsoundstudio.webspace.virginmedia.com/
http://web.archive.org/web/20120313021137/http://www.medsoundstudio.webspace.virginmedia.com/here/trial.htm
https://www.facebook.com/groups/4837052308/
  32-BIT APPLICATION
    WINDOWS XP - Vista - Windows 7)
  MED Soundstudio v2.1
 SYSTEM REQUIREMENTS
Minimum System for MultiMedia use:
P4, 512MB RAM
Lots of available hard disk space
A 'Good' quality  Soundcard
ASIO compliant Sound Card recommended
If ASIO drivers fail, check for latest
drivers or download/install ASIO4ALL
Highly Recommended System for MultiMedia use:
DUAL CORE, Windows XP/Vista/7
1024MB RAM
Top of the range Soundcard
Not required but 'extremely' useful for MIDI work  '-)
MIDI Keyboard
Please ensure you have the latest MS drivers installed
and you do a regular de-frag of your hard drives.
Contact:
RBF Software
169 Dale Valley Road
Bassett
Southampton
S016 6QX
England
Web Sites:
http://www.medsoundstudio.com
http://www.medsoundstudio.info
(c)1990 - 2010  RBF Software
All other trademarks and registered trademarks
are the sole property of their respective owners.
Any modules/samples contained with this file
are the property of the respective owners
and have been used either with permission
from the respective composers or have been
made available to the general public by the
composer via internet sites world-wide.
« Last Edit: February 25, 2021, 06:23:30 PM by chrisNova777 »
