Author Topic: AGP graphics standard introduced (Aug 1997)  (Read 7452 times)
« on: March 31, 2023, 07:26:49 PM »
https://en.wikipedia.org/wiki/Accelerated_Graphics_Port
so basically if you are -using an AGP graphics card make sure your running that os version (or higher) for the hardware to be properly supported. Windows 95 version 4.00.950 B.  or above.
does this mean you cant run windows 3.11 with a motherboard that has an AGP port?? unless they have some special driver to enable the support?
The AGP slot first appeared on x86-compatible system boards based on Socket 7 Intel P5 Pentium and Slot 1 P6 Pentium II processors. Intel introduced AGP support with the i440LX Slot 1 chipset on August 26, 1997, and a flood of products followed from all the major system board vendors.[3]
The first Socket 7 chipsets to support AGP were the VIA Apollo VP3, SiS 5591/5592, and the ALI Aladdin V. Intel never released an AGP-equipped Socket 7 chipset. FIC demonstrated the first Socket 7 AGP system board in November 1997 as the FIC PA-2012 based on the VIA Apollo VP3 chipset, followed very quickly by the EPoX P55-VP3 also based on the VIA VP3 chipset which was first to market.[4]
Early video chipsets featuring AGP support included the Rendition Vérité V2200, 3dfx Voodoo Banshee, Nvidia RIVA 128, 3Dlabs PERMEDIA 2, Intel i740, ATI Rage series, Matrox Millennium II, and S3 ViRGE GX/2. Some early AGP boards used graphics processors built around PCI and were simply bridged to AGP. This resulted in the cards benefiting little from the new bus, with the only improvement used being the 66 MHz bus clock, with its resulting doubled bandwidth over PCI, and bus exclusivity. Examples of such cards were the Voodoo Banshee, Vérité V2200, Millennium II, and S3 ViRGE GX/2. Intel's i740 was explicitly designed to exploit the new AGP feature set; in fact it was designed to texture only from AGP memory, making PCI versions of the board difficult to implement (local board RAM had to emulate AGP memory.)
Microsoft first introduced AGP support into Windows 95 OEM Service Release 2 (OSR2 version 1111 or 950B) via the USB SUPPLEMENT to OSR2 patch.[5] After applying the patch the Windows 95 system became Windows 95 version 4.00.950 B.
The first Windows NT-based operating system to receive AGP support was Windows NT 4.0 with Service Pack 3, introduced in 1997. Linux support for AGP enhanced fast data transfers was first added in 1999 with the implementation of the AGPgart kernel module.
