Author Topic: Guillemot Maxi Studio ISIS (1999)  (Read 16141 times)
« on: January 23, 2015, 03:30:49 PM »
http://www.soundonsound.com/sos/jun99/articles/guillemotisis.htm
4 analog outputs
8 analog inputs
spdif i/o
http://web.archive.org/web/20000303012557/http://www.guillemot.com/uk/index.html
    DSP (Digital Signal Processor): RISC-based Dream™ : Ultra-realistic MIDI with no CPU cost. 4-layer PCB. CD-Audio sound quality (44.1kHz) and Pro audio quality (48kHz).
    Built-in synthesiser with 64-voice GM/GS hardware wavetable and multi-layer stereo 48kHz sampler including 2 LFOs (Low Frequency Oscillators), 3 EGs (Envelope Generators), 2 keyboard tracking tables . Resonance filter of up to 24dB. (Multi-layer: The possibility of assigning more than one instrument to any one note at any time.)
    4MB RAM of high quality samples (sounds included with the express authorisation of Roland Corporation).
    Memory expandable to 36MB RAM with standard SIMM module (<=60 ns) to download new soundbanks.
    Inputs: Mic-In , stereo Line-In, digital game port/MIDI port.
    1 stereo Line-Out + 1 surround output to connect 4 speakers.
    Eight ¼'' analog line level inputs & four ¼'' analog line level outputs.
    20-bit ADC and DAC converters.
    Digital stereo S/PDIF input & output with gilt RCA & optical connection for transfer of your musical creations Direct-to-DAT (Digital Audio Tape) or mini-disc without loss.
    MIDI-In / MIDI-Out / MIDI-Thru DIN connectors.
    Simultaneous recording of 8 sources and playback of 4 sources in hardware full-duplex Monitoring of the 8 inputs to the 4 outputs.
    Listen to your compositions in real-time through both the analog and digital outputs and savour digital quality input for outstanding recordings.
    Choose one of the 4 user-configurable synchronisation master clocks available: 32, 44.1, 48kHz or S/PDIF clock signal.
    Two MIDI ports:
    - One internal port to drive the on-board synthesiser.
    - One external port for external connection.
    True 3D Positional Sound on 4 speakers (no CPU usage) : Set up a real symphonic orchestra at home.
    Real-time Surround on 2 & 4 speakers and 4-band paragraphic equaliser on all sound sources.
    Real-time customisable special effects on 2 or 4 speakers: reverb & chorus on MIDI & Wave; echo, pitch shifting, chorus & reverb on Microphone, CD-Audio, Line-In…
Re: Guillemot Maxi Studio ISIS (1999)
« Reply #1 on: March 05, 2017, 08:06:20 AM »
http://dlia.ir/Scientific/Magazines/SoundandMusic/Sound.On.Sound.Magazine.Sound.Music/1999/GuillemotISIS-jun99.pdf
The software bundle is also quite impressive. As well as the
necessary drivers, Guillemot provide a suite of utilities to control
the hardware and configure the sounds held within the onboard
RAM. Also included are Logic Audio Pro ISIS (close to Logic Audio
Silver in specification), Cool Edit Pro SE and Sonic Foundry’s Acid
DJ (one of several cut down and ‘themed’ versions of Acid now
available). CDs containing demos of various Cakewalk and
Steinberg software complete the package.
Deano
« Reply #2 on: October 23, 2017, 06:28:04 AM »
I have been using one of these for years with win 98se which I keep for programing my Akai s2000.  I could do with the output upgrade on the Akai to really take advantage of the 8 ins of the Maxi. It is such a shame that Guillemot didn't write a driver for xp It is a great sound card with an excellent bundle for the time.
