Author Topic: Future Power FP-SI630E (2001?) Motherboard with 3 PCI slots  (Read 11273 times)
« on: January 13, 2025, 03:37:37 PM »
https://web.archive.org/web/20000520050143/http://www.futurepowerusa.com/
https://soggi.org/motherboards/future-power.htm
https://web.archive.org/web/20010417233811/http://www.futurepowerusa.com/products/FP-SI630E.htm
Special Function
ACPI supporting for OS Directed Power Management
- MODEM Ring remote wake up
-RTC alarm
-Wake On LAN, Keyboard Power On
-Software power off
-Power button
Meets PC 99 Requirement
PC Helath Monitor CPU temprature, System temprature, Sytem voltage (Vcore, Vtt, Vcc3, 5V, 12V...), FAN speed
Main Features
Processor
Support Socket 370 processor for Pentium II/III
Supports Socket 370 processor for Celeronā„¢
Supports Socket 370 rocessor for Coppermineā„¢, (FCPGA, PPGA) VIA Cyrix M III processor, optimized for 133 MHz Front Side Bus Frequency
Chipsets
SiS 630E single chip integrated a high performance North Bridge, advance hardware 2D/3D GUI engine and South Bridge
SiS 950/W83697HF Low Pin Count (LPC) Super I/O
Expansion Slot
Support 3 x PCI Slots and 1 x AMR(Audio/Modem Riser)
System Memory
2 x 168-pin DIMM Sockets up to 1.0GB System Memory
Virutal Channel Memory (VCM) Support
Ultra DMA/66
Support 2 x Ultra DMA/66 IDE Interface Up to 4 IDE Devices & 66MB/s transfer rate
PC'99 Colorful I/O Ports
2x Serial Ports, 1xVGA Port, 1xParallel Port
1xPS/2 Mouse/Keyboard, 1xGame/MIDI Port
1xLine-in/out/Speaker Port
2xUSB Connectors
2xUSB Header (cable optional)
On Board VGA
Ultra-AGP Architecture
Advance HW Acceleration for DVD Playback
UMA Architecture with 2/4/8/16/32/64M System Sharable as Display Memory
Fully DirectX Compliant Engine
Resolution up to 1920x1200 256/32K/64K/16M color @ 80MHz NI
On Board Audio
Integrated 3D Positional Audio Controller
AC97' V2.1 Interface for External Audio Codec
Direct Sound 3D Accelerator, Full-duplex
On Board LAN Controller
IEE802.3.10/100 BASE T Standards
BIOS Boot-up from LAN
Dimension
Micro ATX form factor (24.5cm x19.0cm)
