Author Topic: SoundQuest MidiQuest 2.12 and 3.0 Windows 3.0/3.1  (Read 13774 times)
Offline robbo007
« on: March 27, 2026, 12:49:51 PM »
Hi guys,
I've located a copy of SoundQuest's MidiQuest version 2.12 for Windows 3.0/3.1. The copy has been archived here if anyone wants a copy: https://archive.org/details/mquest_202603
I'm having troubles getting it to see my Roland MPU.401 in Windows 3.1. The MidiQuest software is installed and the Roland MPU-401 driver also. When I load Midiquest it errors with "Midi in Error, The specified device handle is invalid"
The MPU-401 works fine in windows and I can communicate with a Roland MT32 that is attached to it.
Any ideas?
Regards,
« Last Edit: March 27, 2026, 05:57:17 PM by robbo007 »
Offline robbo007
Re: SoundQuest MidiQuest 2.12 and 3.0 Windows 3.0/3.1
« Reply #1 on: March 27, 2026, 06:03:04 PM »
Its all working.The issue was I was feeding the 1.44mb floppy disks like a set of disks when really there are two versions, one on each disk, 2.12 and 3.0. I needed to install one or there other.
After installing using MSDOS, to run in Windows 3.x you need to goto Windows setup, options, Setup Application, Ask you to specify an application, browse to the mquest folder and choose mquest.exe. It then create the application in the Applications Folder. Remember also to add the font .fon file by going into Control Panel, fonts, add font and choose the font inside the mquest folder.
« Reply #2 on: March 27, 2026, 10:46:07 PM »
i could try to help ya out, i have a 386 + 486 with windows 3.x on them
your using the original Roland MPU.401 breakout box + isa host card?
i have a couple kicking around here..
ok i see now u got it sorted ;)
copyright 1991 SoundQuest Inc 66 broadway ave suit 1207 toronto ontario canada m4p 1t6
MADE IN CANADA
https://www.soundonsound.com/reviews/sound-quest-midiquest
