Author Topic: drivers for Iwill SIDE RAID66 (highpoint tech)  (Read 9461 times)
« on: May 15, 2015, 05:14:02 PM »
http://web.archive.org/web/20061019063339/http://www.iwill.com.tw/product_legacy3.asp?na=SIDE-RAID100+&io=T&vID=145&SID=33&MID=26
http://web.archive.org/web/20061019063339/http://www.iwill.com.tw:80/product_legacy3.asp?na=SIDE-RAID100+&io=T&vID=145&SID=33&MID=26
http://web.archive.org/web/20060202082257/http://www.iwill.com.tw/
http://web.archive.org/web/20060427074041/http://www.iwill.com.tw:80/product_legacy.asp
http://kanga.gerbilator.org/drivers/IWill/SIDERAID66/
http://www.slcentral.com/reviews/hardware/controllers/iwill/sideraid66/index.php
http://www.slcentral.com/reviews/hardware/controllers/iwill/sideraid66/page2.php
http://www.slcentral.com/reviews/hardware/controllers/iwill/sideraid66/page3.php
http://www.slcentral.com/reviews/hardware/controllers/iwill/sideraid66/page4.php
http://web.archive.org/web/20010802102154/http://www.iwill.com.tw:80/products/spec.asp?ModelName=SIDE-RAID66&SupportID=
SIDE-RAID66 Specifications
Features
Use HighPoint HPT368 control chip to support PCI bus and Ultra ATA66/33 drive
device to support at least two, up to four peripheral devices support RAID standard:
RAID 0 provides acceleration function,  supports up to four peripheral devices
RAID 1 provides fault tolerance, and two peripheral devices are a group that can support two groups.
RAID 0 + 1, provides acceleration and fault tolerance.
The four peripheral devices are a set of built-in 256 bytes buffer,
and are 32bit/33MHz Bus Master PCI interface.
Support 44MHz PCI bus frequency.
Supported by BIOS, 1Mbit flash ROM is provided.
It can support "hot plug function", allowing you to replace peripheral devices without shutting down.
Provide special external connector for external IDE RAID peripheral device operating system can support,
including Windows 98, Windows 2000 and Windows NT 4.x
